CD4033 Connections For 0 To 9 Counter
maker_2023
Joined Nov 20, 2023
199
You don't mention what is generating the clock or what the forward voltage of the LED is.
If you take the time to read the datasheets, they'll give you the information you need.
From the TI datasheet:
The counter increments on the rising edge of the clock. With a 5V supply, a high level input voltage must be at least 3.5V.
Thanks!
If you were using a red, green, or yellow LED, the forward voltage is probably less than 3.5V.
Input signals greater than 1.5V but less than 3.5V will give unpredictable results.
35,179
Why pull-up and pull-down resistors are needed?
1a) To satisfy input requirements
All inputs, especially inputs with high impedances, require a load on the input otherwise the input becomes an antenna susceptible to random interference. What value resistance to use? You need to know the input voltage and current characteristics in order to determine the range of acceptable values. The calculation is done using Ohm's Law.
Never leave inputs with no connection (NC) to a proper logic voltage level.
1b) For switched inputs
For a low side switch, you need a pull-up resistor. For a high side switch, you use a pull-down resistor. The resistance value is determined the same way as for (1a).
2) When the gate output is open-collector or open-drain
Open-collector (BJT gates) and open-drain (CMOS gates) do not source current. They only sink current. A pull-up resistor supplies source current when a logic HIGH output is desired. Totem-pole (push-pull outputs) can both source and sink current. They do not need additional resistor loads.
Many if not most analog comparator ICs have open-collector outputs.
3) To match the impedance of the transmission line
In high and very high frequency applications, it is important that transmission lines are properly terminated with the correct resistive load. If not properly terminated, the signals will be degraded with reflections on the transmission line. This will be observed on the oscilloscope as "ringing" or oscillations after the leading and trailing edges or a square wave.
4) Bias resistors in networks
RS-485 networks, for example, require both transmission line termination and proper DC bias voltages on the A and B lines.
Hence pull-up, pull-down, and termination resistors are required.
maker_2023
Joined Nov 20, 2023
199
Hi:
Pins 3, 4, 12 and 13 preset pins are floating right now. I looked at the data sheet and
I can't see where it says whether they should be a high or low logic level when up-
counting.
What logic level should they be at and are resistors needed?
What would the input current and voltages be in order to calculate the reistor values?
M
35,179
On the CD4510, pins 4, 12, 13, 3 are the BCD inputs for presetting the counter.
If you do not need this function, connect the pins to GND.
35,179
The "carry out" will be used when I add other display stages, but until then, should
pin#7 be left hanging?
Think of input as your ear and output as your mouth. You don't want to stuff something in your mouth and gag.
Pin-7 carry-out is an output. Never connect outputs to Vcc or GND. Leave them not connected.
dl324
Joined Mar 30, 2015
18,467
Unused inputs can be tied HIGH or LOW, whatever is more convenient.
10k resistors are commonly used for CMOS. The values aren't very critical because the inputs don't draw significant current.
If preset isn't going to be used, you can connect them directly to VCC or GND.
eetech00
Joined Jun 8, 2013
4,724
Hi:
counting.
This info can be deduced from the datasheet. It is described in the description at the top.
The timing diagram can be used for further clarification.
35,179
CD4510B Electrical Specifications
Assuming VDD = 5V
We are focusing on data (in yellow boxes) at +25°C
Input Low Voltage VIL Max = 1.5V
Input High Voltage VIH Min = 3.5V
Input Current IIN Max = 0.1μA
In order to present a logic LOW input, pull-down resistor R = VIL / I = 1.5V / 0.1μA = 15MΩ
In order to present a logic HIGH input, pull-up resistor R = (VDD - VIH) / I = (5V - 3.5V )/ 0.1μA = 15MΩ
You can see that you have a very wide range of resistance values to use.
10k - 100kΩ will work fine for CD4000 type CMOS gates.
maker_2023
Joined Nov 20, 2023
199
Assuming VDD = 5V
Hi:
I now have the 10s digit counter stage wired up. It just displays a zero while the units stage counts
to 9. I connected the "Carry Out" of stage 1 to the "Carry In" of stage 2. Not sure what to do with
pin 9 (Reset) of the stage 2 counter. Schematic attached.
M
maker_2023
Joined Nov 20, 2023
199
Assuming VDD = 5V
Sorry, not sure what you mean here. Isn't 15Meg the only value?
sarahMCML
Joined May 11, 2019
703
Hi:
M
Just tie all the reset pins together if you want a "Power On" reset. And you've left the "Presets" (pins 1) unconnected again!
35,179
No. 15MΩ is the maximum limit.
But you don't want to go there.
What is the minimum value? The minimum is 0Ω.
Hence your range of suitable resistance is 0-15MΩ.
0Ω is considered a short circuit and absolutely nothing wrong with this except that there is no excessive current protection if something goes wrong.
It is best to stay within a modest range such as 1k - 100kΩ.
35,179
Hi:
M
Remember this rule - Leave no input pin not connected. In other words, input pins must be connected to a proper logic level voltage.
Pin-15, CLK is an input pin. What are you going to do with that? Connect it to pin-15 of the previous counter.
Since RST, pin-9 is active HIGH, connect it to GND to disable RST (or connect it to pin-9 of the previous counter).
maker_2023
Joined Nov 20, 2023
199
OK. Got it. Thanks.
