ronsimpson
- Joined Oct 7, 2019
- 4,888
One reason I suggested 4 smaller supplies is that exactly what you want uses common parts, the circuit is in a data sheet, the inductor is common.
Paralleling: Lets say there are four supplies. 36.0V, 36.1V, 36.2V, 36.3V. If the load is light and can be lifted by one supply the 36.3V one will be supplying the load. If the load is over what one supply can do, then it will be at 36.2V and one supply will be at current limit.
Option, Build one supply like normal. Build the next three with the input to the error amplifier at ground. This will cause the error amplifier to lift as high as it can. (almost any PWM but not the TL494) Most error amplifiers pull down strong but lift up poorly. Now wire all four error amp output pins together. Now all four PWM will run at the same current level. (same current if a current mode like the 3842 or same duty cycle like the voltage mode PWMs) This is common practice.
Thank you for your comment. I understood the concept, and it is a nice to know practice for parallel converters. I will go for the current mode with UC3843, if i decide to make the design with more then one boost converter.There are many different ways to make a PWM.
Current mode; A clock turns on the MOSFET. Current ramps up in the transistor. (current is monitor) When the current reaches a set point the MOSFET is turned off. The error amplifier controls the turn off point.
Voltage mode; The current is not looked at. A clock turns on the MOSFET. It is turned off in some uSseconds later. The error amplifier controls how many uS.
In all PWM the error amplifier looks at the output voltage and adjusts something to get the desired output voltage.
Look at the case of the voltage is a small amount too low. In current mode the error knows it is now pushing 1A to the load but it need to move up to 1.1A. In voltage mode it is set to 50% now but must move to 51%.
Thank you for your answer and exertion on the uc3842 circuit. I will try a similar circuit in LTSpice and simulate it. Thanks again.Here is a small 12 to 36 boost using a current mode UC3842.
Updated the sch. Now running at 100khz.
Thank you. I am a little bit undecided that whether i want to use low current commercial inductors with parallel converters or i want to design an inductor and wind it for only one converter circuit. Turns, ferrit measurements, wire gauges etc. are okay but i am not sure how can i achieve a good current accuracy, precision and stability.Here is my file.
I want to bring up this situation to you too Mr. Irving. If i design and wind up a new inductor i can raise inductance values around 100 µH - 200 µH and switching frequency will be lower, so ripple will be lower right? What are your toughts about winding a new inductor vs lower current inductors with parallel converters? I am soo undecided right nowBoth... each supply will see the averaged joint-voltage and will adjust its output accordingly. If one is a higher voltage than the other due to transmission losses then it supplies more current which will cause its output to drop and other supplies will take up the load. Ideally the feedback sense input for all PSU will be tied to the same location at the load...
No, ripple is worse if you lower frequency and increase inductance... Here,V(out) is 50uS/15uH v V(out2) at 5uS/1.5uH for the same output capacitor. To reduce the ripple on the lower speed version you need to increase C to 2000uF which makes settling time 30mS+I want to bring up this situation to you too Mr. Irving. If i design and wind up a new inductor i can raise inductance values around 100 µH - 200 µH and switching frequency will be lower, so ripple will be lower right? What are your toughts about winding a new inductor vs lower current inductors with parallel converters? I am soo undecided right now
Limited to 50% mark-space ratio, and you need 75%.Also what do you feel about UC2845 ?
Thanks. For a different mosfet it can be used, right?Limited to 50% mark-space ratio, and you need 75%.
See post #9
A different MOSFET won't change things.. in my simulaton you can see its ON-time is 3.5uS in 5uS, 70% duty cycle. If the controller is limited to 50% then you're scuppered.Thanks. For a different mosfet it can be used, right?
If you are running 100khz and higher, think about Litz wire. Read up on skin effect. A large wire will not help much at high frequencies.Are wire gauge specifications enough?
Duty cycle = 1-(Input/Output) plus a little bit to allow for diode voltage drops etc.A different MOSFET won't change things.. in my simulaton you can see its ON-time is 3.5uS in 5uS, 70% duty cycle. If the controller is limited to 50% then you're scuppered.
One has to consider the spectrum of the inductor current. The majority of it is DC, for which the skin effect does not apply.If you are running 100khz and higher, think about Litz wire. Read up on skin effect. A large wire will not help much at high frequencies.
