Designing a real buck converter I have run into a unsolved issue.
Samantha Groves
Joined Nov 25, 2023
186
Hello.So I want to build a buck converter on a breadboard.The PWM frequency will be close to 1000Hz and I will be using a 2.2mH inductor.
I want my buck converter to operate in CCM.The target output voltage is 6.5V bcs I want to be able to power a RGB led.I am targeting at a continuous current of 10mA which means ripple current cannot be above 10mA if I want it to run in CCM and preferable 1mA ripple current is the target.
Well the math dont workout.For a 6.5V target output at Vin = 100V at 1000Hz oscillation frequency and a 2.2mH inductor the ripple current is much larger than 10mA let alone 1mA which is the target.Any solutions?
panic mode
Joined Oct 10, 2011
5,448
making correct schematics would also be a good start. you have N-MOS there and it is wired backwards. for that to work it would be P_MOS but driving it need to be handled. or.. keep N-MOS but wire it on the low side... and what do you want with 6.5V at GND?
