keiichicom
Joined Apr 26, 2022
87
Hi, I think that this looks correct, please confirm. I am ONLY showing my connection to the 62256 32k x 8 ram CE pin that I added to the web page picture, slide 15: When A13,A14,A15 are all low, the 2764 should be selected. When A15 is high, the 62256 should be selected.
Keiichicom
ericgibbs
Joined Jan 29, 2010
21,651
hi k,
I see that you are using a 32K byte RAM. ie: A0 thru A14 address lines, so why the decode on A13/A14.
Use A15 as ROM / RAM select.
E
Edit: do you have a complete circuit diagram to post, we can then give more defined help.?
