8085 memory/address decode 32k x 8 / 32k x 8 ram/rom split question
keiichicom
Joined Apr 26, 2022
87
Hi, please check my pic below and comment on any potential issues that you find (assuming no I/O at this point). Some connections not shown for clarity:
Thanks, Kei
35,280
That is not how one would normally do it.
The upper address lines go to the 74138 which determine which /CE is selected.
/RD goes to /OE.
I have not done this in a long time and will have to review how to interface with 8085 chips.
ronsimpson
Joined Oct 7, 2019
4,856
It has been many decades since I used the 8085. I liked the part very much. My memory is not good, so I looked for an example of an 8085 memory mapping.
You do not need the area in red. I think the red is the same as your inverter.
I think you are good.
keiichicom
Joined Apr 26, 2022
87
/RD goes to /OE.
I have seen that way too, Mr. Chips. In my case it is simpler since my only upper address line is a15, hence the inverter for 0000H-7FFFH and 8000H-FFFFH, add the memory signals to 74138 give those outputs. Although I admit I got inconsistent results, As long as I don't have to retrieve a value from ram/rom the programs always work, but sometimes if I have to retrieve a value from rom/ram my program does not work (retrieves wrong value).
I will try it the way you suggested.
Thanks, Kei
keiichicom
Joined Apr 26, 2022
87
Thanks, Ron, I match the way you describe, I am not sure why I am having issues lately (I rebuilt my 8085 computer after the previous one died on me). I will try it on a solderless breadboard first, before I solder another one up...
-Kei
