Do FRAMs need their CE (bar) signal pulsed?
keiichicom
Joined Apr 26, 2022
87
Hi, do FRAMs need their CE(bar) signal pulsed at every r/w access, unlike SRAMs?
Example: Infineon FM18W08 Parallel 5.0V which can replace the 62256 SRAM / 28c256 EEPROM.
What if If I do this: 8085 A15 to input to 1 of the 74HC04 inverters and to CE(bar) (pin 20) of FRAM 1. and output of the inverter of 74HC04 to
FRAM 2 CE(bar) (pin 20), It won't work right?
Thanks, -Kei
dl324
Joined Mar 30, 2015
18,523
According to the datasheet, CE# must be taken LOW for each read or write access:
