I would assume that if pin 3 is ground then pin 2 would likely also ring to ground using a continuity test meter. Current would be different but the potential to ground will likely appear to ring to ground. IF pin 1 is connected to B+ (common term for positive voltage on a voltage bus) then pin 2 is probably ringing to B+ as well when using the continuity meter.What do you mean by "wiper also rings to ground"?
I always use bourns for this kinda thing.
For a true tenst one would test for voltages with the unit powered. The potential between pins 1 & 3 would read out as a voltage somewhere between B+ and ground.
That is why we need CCI was thinking of using multi turn pots like you said but If there is a problem, you cant turn them down fast enough.
this is why I like tonys use
Tony would putting a resistor on the 3 pin on VR2 prevent this from over loading the circuit. I.e. Vr1 500k, Vr2 5k then on pin 3 of VR2 add a 500 ohm resistor between the pin on 3 and the board?Just be sure you never drop the resistance to zero across pins 1 & 3 on the board.
On VR1 between pins 1 & 3 will ALWAYS be (in this case) 200KΩ. And I believe if you may have inadvertently mixed up the two pots when your board blew out, 200KΩ will never be anything different than the 200K across pins 1 & 3. IF you inadvertently put VR2 where I show VR1 then between pins 1 & 3 could have been as low as (in this case) 2K, which may account for the blown board. If you add the resistor as per your drawing it will just increase the resistance either slightly or significantly, depending on what you put there, but it will never cause any harm.
Personally I don't think it's needed. Even if VR2 is cranked all the way down to zero ohms, there will still be 200K present. So, no, you don't need the extra resistance.
One final thought on VR1 & 2, they need to be "Linear Taper" and NOT "Audio Taper" pots. You won't like the result using Audio Taper; their resistance won't sweep steady across the range of resistance on pin 2.
Actually, after giving it some more thought my original drawing won't achieve the fine adjust, all it will do is slightly alter the current in the circuit. The drawing below will do better at giving you a voltage adjustment (not current); which by the way, having the extra resistance wouldn't have given you any more current, it would have reduced the current. So my modification wouldn't have blown up the board. However, if you hooked the fine adjust across the Vcc & Vgg then that could be the reason why you blew out a board. Another good reason for the changes I made to my drawing. Minor changes but no matter what, you shouldn't have blown up a board from my first drawing. You should also understand that when setting to the lower limits the fine adjustment will become less affective whereas at the higher limits the fine adjustment should be more sensitive. Just be sure you never drop the resistance to zero across pins 1 & 3 on the board.
[edit] The new drawing should make it clear how to hook up the fine adjust pot (VR2). This can be on either side, connected to pin 1 (of VR1) or on pin 3 (of VR1). VR1 should be your coarse adjustment and should be wired in place of the original variable resistor that was originally on the board. VR1 should be the 200K and VR2 should be the 2K. If (in my original drawing) you got those reversed then that could account for blowing out the board. Be SURE to follow the drawing, and make sure everything is right before you power it up. If it blows up again - then there's something going on that I'm unaware of.
1a) Correct.
1b) Correct. This is for all pots replaced. As long as you keep the proper value.
2) You don't need an additional resistor. Just use the fine adjust to tweak the voltage.
3) Yes, VR1 will always be the bigger pot.
4) Yes.
5) That's what I recommend.
The reason why you probably blew the board was because originally, between legs 1 & 3 the board expected to see 200KΩ, meaning if it were adjusted to 10 volts (for example) the pot would see 50 micro-amps. Using a 2KΩ in the wrong position would have resulted in seeing (at 10 V example) your board would see 5 milliamps. 100 times more amperage with the wrong pot in place.
Of course I don't know what the potential between pins 1 & 3 are in any of the circuits so all I can do is pick at random some example to make my point clear. (hopefully)
