SMPS Power Schottky rectifier replacement
sab201
Joined Nov 18, 2023
322
Good Day,
I opened up a 220 Volts AC to 5 Volts DC SMPS power supply module. There was no DC output, the Power Schottky rectifier is shorted and damaged. Here are its details:
STMicroelectronics 45 V 40 A Diode Schottky 3-Pin TO-247 STPS4045CW
I wish to know if I can replace it with the following:
SBDF4045LCTB-JSCJ-45V 40A TO-220F Schottky Diodes ROHS
because the latter is less expensive and easily available.
Please advice if this can be done.
Thanks.
lichurbagan
Joined Jul 4, 2025
137
Electrically, both are dual common-cathode Schottky rectifiers with the same 45 V, 2 × 20 A rating and pin order:
  1. Anode
  2. Common cathode
  3. Anode
However, it is not a true drop-in replacement. The original TO-247 device has better thermal performance and a 175 C maximum junction temperature, while the insulated TO-220F replacement has higher junction-to-case thermal resistance and a 150 C limit. It may overheat at the same load, despite having the same advertised current rating.
It could work if the supply operates well below 40 A and the replacement is mounted correctly to an adequate heatsink, but I would prefer another TO-247 part with equal or better voltage, current, forward-drop and thermal ratings. Also check the output capacitors and load for shorts before powering it again, as the failed diode may be a symptom rather than the only fault. Use appropriate isolation precautions because the primary side carries lethal mains voltage. You should check this SMPS power supply board: https://www.pcbway.com/project/shar...sign_for_Different_Applications_cfd0a641.html
sab201
Joined Nov 18, 2023
322
Ok then I will go with the original one. Thanks for the information. That is not mounted on a heat sink and there is no cooling fan as well. So it would overheat. The current rating of the module is 20 A and I would only use max 10 A so even though current is lesser I suppose the overheating problem is there.
lichurbagan
Joined Jul 4, 2025
137
Yes, the original TO-247 part is the safer choice. Even at 10 A, the diode can dissipate several watts because of its forward-voltage drop, and without a heatsink its junction temperature may still rise considerably.
Also check the output capacitors and load for shorts or excessive ripple current before fitting the replacement, the failed rectifier may be a symptom rather than the original fault.
38,826
Is it possible to add a small, black heatsink to that diode (?), as it appears that it likely will overheat even at 10A of current.
sab201
Joined Nov 18, 2023
322
Yes that could be the case. Thanks for pointing it out I will try to add heat sink and operate the module. Initially I thought it was of 20 A rating so that should be ok to draw 10 A current from it. That damaged the rectifier. Possible cause could be overheating.
kiroma
Joined Apr 30, 2014
213
Years ago I had the lazyness to calculate the power a single resistor would dissipate and thought an educated guess would do. Tried a 0.25 W and it fried right away. From that day on, I calculate, even if in my mind. Thinking the circuit can handle is deceiving sometimes.
sab201
Joined Nov 18, 2023
322
I thought I could give in my input after trying to repair that SMPS I tried replacing the rectifier with heat sink and replacing two other MOSFETs. Still something else is also damaged due to this overheating problem and no cooling fan is provided. Nevertheless I found repairing it and modifying it will be more time consuming and expensive than the SMPS itself.
I ordered a desktop computer CPU SMPS that matched my power requirements and it has three outputs 3.3V, 5V and 12V, very useful for my application, I only have to short a green and black wire to turn it ON. Regret not getting this idea first. Its working perfectly stable and fine.
