What am i doing wrong here?
tienk
Joined Apr 8, 2024
76
Getting "could not open file.." shown in the first image, when trying to do transient analysis, is my circuit wrong or am i missing something
33,198
Hard to say for sure, since you don't even indicate what simulator you are using.
The usual reason for not being able to open a file is either that the file name is not correct, or the file is not located where it should be. If neither of those is the culprit, then another possibility is that the file is locked by another application, such as might happen if you have it open in an editor.
tienk
Joined Apr 8, 2024
76
this is ltspice
tienk
Joined Apr 8, 2024
76
No. Both relays use the same model file.
Place the cp1-12.txt in the same folder as the schematic.
Then place this directive on the schematic:
.inc cp1-12.txt
how exactly do you add the directive on the schematic:
.inc cp1-12.txt
so i place the text file in the same folder as the cp1-12 or cp1a-12, and how exactly do i add the directive on the schematic, sorry im a beginner
eetech00
Joined Jun 8, 2013
4,724
1. Click on the schematic to give it active focus. Then type the letter "t" to open a text window.
2. Select the "Spice directive" radio button.
3. Click in the text box and type ".inc CP1-12.txt" without the quotes.
4. Click "Ok", the text widow will close and the text will be attached to the cursor.
5. Click on the schematic to place the text on the schematic.
6. Done
Yes. Place the cp1-12.txt file and both .asy symbol files in the same folder as the schematic .asc file.
tienk
Joined Apr 8, 2024
76
just to make sure is this the right symbol
6. Done
Added it but another question, in this symbol for cp1-12 which are the pins exactly like which are the coil pins and which is the NC and NO
eetech00
Joined Jun 8, 2013
4,724
Yes. CP1-12.asy is for CP1-12 and CP1a-12.asy is for CP1a-12. But they both use CP1-12.txt model file.
From datasheet page 5:
tienk
Joined Apr 8, 2024
76
for some reason it still says the same thing, the txt file exists within that folder
tienk
Joined Apr 8, 2024
76
I don't what your referring to but that's not the symbol I posted.
Post your LTspice schematic and I'll add the relays and upload.
i have added the schematic file and the image of how it should be, but that is the symbol in the file for cp1-12
