LM723 + Power MOSFET doing linear regulation ..#2
marvi3
Joined Apr 5, 2021
Non aprirò un tread ulteriore, il mio intento è du costruire un'ali lineare con il 723 ed un funale con due mosfet, per avere una disponibilità dui tensione da 50 va 450V e 250 mA, e mi chiedo se devo osservare un qualche accorgimento perché è la prima volta che uso i mosfet in lineare.
questo è lo schema di massima che intendo usare... ovviamente sostituendo i finali con due mosfet
Mod: Created a new thread.
Link to old thread.
https://forum.allaboutcircuits.com/...t-doing-linear-regulation.204809/post-1960867
sghioto
Joined Dec 31, 2017
8,765
English only please !!!
dl324
Joined Mar 30, 2015
18,524
Translation:
I will not open another thread; my intention is to build a linear amplifier with the 723 and a power stage with two MOSFETs, to have an available voltage from 50 to 450V and 250 mA, and I wonder if I need to take any precautions since it’s the first time I’m using MOSFETs in linear mode. This is the rough schematic I intend to use... obviously replacing the output stage with two MOSFETs.
28,612
Translation:
There will be a serious challenge in using an LM723 regulator in a 450 volt circuit. Check the data sheet for the specifications and voltage limits of the 723 device.
For the "Linear Amplifier" you need to tell us the intended output power and the desired frequency range to be amplified. It would also be useful to know the intended amplifier input power level.
panic mode
Joined Oct 10, 2011
5,476
D1 is a 10W zener diode and 2N3234 is good for 160V. but getting to 450V will require some tweaks. for example replacing D1 and R5 with small dedicated supply. R6 would need to be adjusted to some 16 Ohm to have current limited to 0.25A. transistor will need to handle high voltage and power dissipation since linear regulator.
38,952
250mA with a 400V drop is 100W of dissipation, so the transistor(s) will need to be on a large heat-sink, likely with fan cooling.
