Metal Project Case connected to Power Supply Neutral
PeteHL
Joined Dec 17, 2014
597
My plan is to put an audio processing circuit in a metal case. The power supply for it is linear bipolar +/- 13V. This will include RCA (phono) jacks attached to the case; this will connect the case to the power supply reference potential. Should making this connection be avoided or is it acceptable?
ZhangSheng
Joined Sep 25, 2026
24
可以接,但只能单点接,不要形成环路。±13V 的 0V 是变压器次级的参考地,不是市电零线(N),机壳不要直接接市电零线。
建议做法:RCA 外壳、电源 0V 和机壳在一点汇合(星形接地),用不小于 0.75 mm² 的短线连接,连接点电阻应小于 0.1 Ω。通电前先测机壳与 0V 之间无短路;通电后测机壳与 RCA 外壳之间的交流电压,正常应小于 5 mV,音频输入端对地直流偏置应小于 10 mV。若测到 50 Hz 交流电压明显偏高,说明存在接地环路,应改为单点接地并检查变压器屏蔽层和电源滤波电容的接地点。
