Use MOSFET to control AC power input to transformer
ronsimpson
Joined Oct 7, 2019
4,851
Although this switch will be replaced by an SSR, I’ve considered this issue: can the ground for the driver be shared with the ground of the AC circuit?
If you use a SSR there is isolation, no problem. Probably 2000 to 4000V of isolation.
I don't know what power you have in your country. The "cold" side of the power line is not really at ground. It could have some voltage on a good day. It is too common for Line and Neutral to get wired backwards. You should consider either wire of the power line might be at 120 or 220.
I placed this snubber because
Snubber on DC often have a diode. Snubber on AC do not.
