Use MOSFET to control AC power input to transformer
schmitt trigger
Joined Jul 12, 2010
2,292
Sorry, I just checked a lot of information. I can probably understand what you mean.
Because the professor told me earlier that using triac would prevent the circuit from starting at zero voltage. I think he may be wrong.
I have a component here, but it's in Chinese. Can I use this module to directly link the bit I want to control without connecting Mosfets?
https://www.taiwansensor.com.tw/product/1路5v低電平觸發固態繼電器模組-ssr-固態繼電器-帶保險/?srsltid=AfmBOopGV3xc3J3vdmyKG7o2vqdRJypbdcZiRcbb0UpXnLshv0po1ATp
If you scroll down you’ll find an English translation
LowQCab
Joined Nov 6, 2012
5,102
There are NO simple, but accurate, methods for doing what You want.
This is, of course, only my feeble opinion,
and I am definitely NOT qualified to design High-Frequency-Transformers,
I know just enough to be dangerous,
and to know that High-Frequency-Inductors and Transformers are very complex, and fickle to work with.
There are probably people in this Forum who could better answer your question,
but as for whether or not they would be willing to donate the
ridiculous number hours required to teach You all about it, ( in a Forum no less, and for free ),
well, that may be a different story.
There may be commercial-equipment that can provide the answers You are looking for,
jackxieeeeee
Joined Nov 27, 2024
17
Thank you! I understand!!
But
Why do you say it's dangerous?
I believe what you said, but I don't know why.
jackxieeeeee
Joined Nov 27, 2024
17
Yeah a solid state relay as mentioned several times.
Only rated 2 amps at 240 vac, is that sufficient?
I'll try it first.
It should be enough for now.
But if it's not enough in the future, I can only change the module, right?
Or can I adjust the circuit to achieve it?
sghioto
Joined Dec 31, 2017
8,763
I suppose the actual SSR could be replaced on the module but probably cost just as much as a module with a higher current rating.
jackxieeeeee
Joined Nov 27, 2024
17
Sorry, I forgot to mention that my switch is located on the first side of the transformer.
The forum has merged my article.
At the beginning, I used the configuration of the timer, but he will replace it with arduino.
Will such a load affect the current of SSR (will it lead to excessive instant failure)
28,600
How about a trick I came up with many years ago: Rather than two devices in series, us a silicon diode bridge rectifier and a single control device between the two DC terminals, while the two AC bridge terminals are in series between the AC source and the AC load. Then it can even work with a bipolar transistor, or even a vacuum tube.(I do not recommend that). Only one series device then needs to be controlled. It worked back in 1969 and allowed a single SCR to control both phases of an AC power feed to a transformer.A simple way to regulate a high power DC power supply.
jackxieeeeee
Joined Nov 27, 2024
17
I wouldn't think so with a 4V AC supply.
Is this using the schematic in post #1?
Yes!!Thank you!
I made some slight modifications: in the RC circuit, the switch has been replaced with an SSR (solid-state relay).
Is there anything else I might need to modify in the RC circuit?
jackxieeeeee
Joined Nov 27, 2024
17
Thank you!!
Are there any related articles? I’d like to understand the principle behind it.
Danko
Joined Nov 22, 2017
2,256
Here you can read about @MisterBill2's invention:
https://www.electroniclinic.com/scr...rent-control-emergency-lighting-over-voltage/
ronsimpson
Joined Oct 7, 2019
4,894
MOSFETs are turned on/off by the voltage from Gate to Source. They do not care what the voltage is from Gate to Ground!
The Gate drive voltage is VCC and GND which is not connected to the MOSFETS. There are two grounds in the page that are not related. If V1 was the power line G! & G3 would likely break. There is an undefined voltage (probably too much) being applied to the Gates.
Why a snubber across T1? I don't see a reason for D1. The snubber will only work for 1/2 the power cycle.
jackxieeeeee
Joined Nov 27, 2024
17
I can roughly understand what you mean.
Although this switch will be replaced by an SSR, I’ve considered this issue: can the ground for the driver be shared with the ground of the AC circuit?
jackxieeeeee
Joined Nov 27, 2024
17
I placed this snubber because I saw some examples and content in certain information and articles.
Here’s my thought (though I’m not sure if it’s correct):
When I switch the circuit, the transformer generates a back electromotive force (EMF) that could affect my other components.
Initially, I only connected a diode.
