use a transistor and two capacitors to turn on an LED and close it gradually
soleclam
Joined Oct 24, 2024
Hi, I'm a physics student, and I have a small problem for a lab that I have to solve.
Here is my problem: I must create a circuit which uses capacitors to gradually close a light, but in addition, we must pass the current from the capacitor which discharges by the base of an NPN transistor.
A picture of what I'm trying to do is below. The top circuit is the complete circuit tying everything together. The bottom circuit is the same, but divided into 3 parts which are not connected (the diodes present on this circuit are just used to show that it is a connection point between parts 1 and 2 or 2 and 3)
Circuit design Smooth Hillar - Tinkercad - Opera 2024-10-24 23_36_49.pngThe question I have for you is can you find the error in my circuit and how to fix it? Individually part 1 (left) works, it's just that the capacitors do not discharge. Part 3 (right) works entirely if you remove the transistor and put a wire in its place (causes the light to turn on infinitely).
Part 2 (middle) is just used to bring together the two parts to allow the capacitors to discharge in part 3 and allow the current from the battery of part 3 to turn on the light and gradually let less voltage pass the more the capacitor empties.
If you are interested in helping me, you can fix the problems my current circuit has by adding new components or removing some.
You can also create another completely different circuit that does what I need. the only thing is that I am limited to using NPN transistors, switches, 3V batteries, resistors, capacitors,
a bulb (led) and multimeters
Description of the image components:
-the black thing with a big N is the transistor
-the large black cylinders are the capacitors
Sorry if my circuit is not the clearest I am still a beginner in the subject.
BobTPH
Joined Jun 5, 2013
11,678
I am not going to try to interpret that diagram. Schematics are the language used to specify circuits. Post a schematic please, labeling all the parts and their values or part numbers.
And what does “gradually close a light” mean?
boostbuck
Joined Oct 5, 2017
1,067
Sorry to say your diagram is unintelligible. I did try.
I urge you to learn and be comfortable with standard circuit diagrams if you want to ask others for assistance. The abstraction of the symbols in circuit diagrams might take a bit of getting used to, but that's what makes them effective.
If TinkerCAD is some kind of simulator, there are better ones available.
boostbuck
Joined Oct 5, 2017
1,067
Having time on my hands, I unravelled your 'circuit' thus, I think it is what your layout is:
For starters:
1) why capacitors in series?
2) two separately supplied circuits without a common
3) no conduction path for the transistor base
