- Joined Jul 18, 2013
- 30,887
I actually meant to try the lamp idea without the motor connected at all, just the lamp across the respective pair of terminals on the board.
Yes, I understood that. I just wanted to make sure I understand how to do the test. I told you I’m an amateur, haha. My question is, do I put the red wire in contact with the electrical foot contact on the bulb and the white wire on the screw contact, then turn the armature to get the bulb to light?I actually meant to try the lamp idea without the motor connected at all, just the lamp across the respective pair of terminals on the board.
It appears to be a MOV metal oxide varistor otherwise known as a VDR voltage dependant resistor.The "bluish thing" is a three terminal variable resistor, and if it is damaged that might be the source of the problem, or not. But since the motor seems to be in OK condition it may make more sense to buy a new speed controller made for universal motors such as this.
Where could I find a speed controller and how would I know it’s a suitable this motor? Second, would I just simply remove the speed controller from the circuit board and attempt to solder the new one on? Maybe it would make more sense just to get the variable DC voltage supply drive for the motor. (I assume the variable voltage will control the speed?). And again, where would I find that and make sure it’s the right specs for my motor? Thanks.The "bluish thing" is a three terminal variable resistor, and if it is damaged that might be the source of the problem, or not. But since the motor seems to be in OK condition it may make more sense to buy a new speed controller made for universal motors such as this. Open loop speed control can produce acceptable results on a lathe, since the basic control requirement is ueually either "Fast" or "Slow", although some talk about specific surface speeds for specific cutter. And you might find it satisfactory to simply use a variable voltage DC supply to drive the motor.
Isn’t that something you can build? What’s the cost look like?It appears to be a MOV metal oxide varistor otherwise known as a VDR voltage dependant resistor.
IMO the jury is still out on the motor technology, shunt or series field, IF a Universal motor a AC Triac controller would run it.
Ah thanks, that is what I was doing. I don’t understand why that doesn’t work though. Isn’t it current and amperage coming directly off the motor, and why won’t that provide what’s needed to light the bulb?Jdi2010,
Reading your post #64 you seem to have misunderstood the test with the lamp. You seem to have connected the lamp to the motor. It should have been connected to the wires FROM the control board that would normally be connected to the motor.
Les.
On my DC lathe, I use a KB Electronics brand controller (http://acim.nidec.com/drives/kbelectronics/products/variable-speed-dc-drives/dc-drives-chasis ).Where could I find a speed controller and how would I know it’s a suitable this motor? Second, would I just simply remove the speed controller from the circuit board and attempt to solder the new one on? Maybe it would make more sense just to get the variable DC voltage supply drive for the motor. (I assume the variable voltage will control the speed?). And again, where would I find that and make sure it’s the right specs for my motor? Thanks.
Would I just test the varistor with an ohm meter, or how would I test it?If that "bluish thing" is indeed a MOV used for circuit protection it may have done it's protection service and become permanently short circuited. I have experienced that in several instances. It would certainly explain the overheating series resistor as well. So checking that device to see if it has gone to a permanently low resistance will let you know. But it also looks like a variable resistor that has been glued into a fixed position.
If it has wire leads then it is probably the varistor as Max suggested, while if the back side looks like metal, and the leads soldered into the board are flat , then it is more likely the variable resistor.
If you can take another picture that shows the whole thing, including the leads,the answer will be more certain.
The Triac 'Dimmer' style controllers are relatively cheap, but you would need to ensure the motor is a Universal version first, these have the power connected across the series field and armature.Isn’t that something you can build? What’s the cost look like?
Yes, make sure you use the lamp across the board outputs as already indicated, the motor is not connected at all.Ah thanks, that is what I was doing. I don’t understand why that doesn’t work though. Isn’t it current and amperage coming directly off the motor, and why won’t that provide what’s needed to light the bulb?
We have seen the pictures of the brushes and thus most of us have concluded that it is indeed a universal motor. In addition, looking at the windings in the photo, which are not that many turns of fairly heavy wire, another conclusion is that it is most probably a universal series type motor, with a connection for monitoring the armature voltage.The Triac 'Dimmer' style controllers are relatively cheap, but you would need to ensure the motor is a Universal version first, these have the power connected across the series field and armature.
No third wire, white, in your case.
The KB and treadmill style controllers will not run a series (Universal) motor.
