Shortcircuit diode troubleshooting
andrew74
Joined Jul 25, 2022
273
Hi everyone, I'm trying to figure out what's wrong with this mini remote control used to open a gate.
In the middle space you see in the photo, there was a small battery that's charged (now I removed it), and when you press the buttons, the two LEDs (on the button) light up, but the gate doesn't open.
I checked that all the resistors had the right value and that there were no short circuits in the capacitors.
So I was analyzing what I think is a diode for which I attach the datasheet.
https://www.mouser.com/datasheet/2/...oOSiRTamsQaSlfa_Zckhu1zt36v1iDDzv5e673qDRh1c_
Mostly, in the two nearby capacitors, I measure a resistive value that isn't infinite, like in all the others in the circui
The first question is whether I'm correct in saying that the diode burned out at one of the two anodes, and the second question is whether the resistance seen across those two capacitors could be provided by a parallel resistor
WBahn
Joined Mar 31, 2012
33,320
In general, you can't measure component values while the component is in a circuit. When you try to measure the across the capacitor, for instance, all you are doing is measuring the effective DC resistance of everything else connected to that capacitor. It's a meaningless measurement.
It's hard to really say if the measurement across the diode (if that's what it is) indicates a short circuited diode or not. Again, you have everything else in the circuit confounding the meter's ability to make a meaningful measurement. You need to lift at least the cathode off the PCB.
panic mode
Joined Oct 10, 2011
5,427
when i work on something, i try to first get the power rails identified, as well as major components and connections to surrounding parts. component you are looking at may be BAV70 and probably many other things - there is a lot of products in that form factor and just as many with marking A4:
https://smd.yooneed.one/code4134.html#code4134
i would suggest to first see the scale of part (is it really SOT-23 package), try to power it up and measure voltages around it. btw when testing not powered circuit with continuity tester, always swap probes to get readings from each direction. what you see is DC resistance but since many parts are polarized (diodes, transistors,...) getting bigger picture is important.
Pyrex
Joined Feb 16, 2022
565
First of all, how did you determine that the remote control isn’t working, and not the signal receiver at the gate that receives the signal?
Secondly, as I understand, the remote control sends a radio signal? If so, first you need to make sure that the remote control is sending a radio signal.
And your earlier measurements are of little use, as was mentioned in previous posts
andrew74
Joined Jul 25, 2022
273
Hi! How do I verify if it is actually sending a signal?
andrew74
Joined Jul 25, 2022
273
Thanks for the advice, I'll try it.
I'm also asking if you have any suggestions on how to check if the radio signal is coming out of the pcb
tautech
Joined Oct 8, 2019
507
Likely a 315 or 433 MHz telemetry signal of which you should see something on a scope of sufficient BW and certainly with a spectrum analyzer. With a scope you can do a direct connection but with an analyzer a noncontact RF loop would be recommended.
28,512
You can also use a pickup coil and a simple diode to drive a voltmeter to sense an RF signal. Usually that works. Not always.Really, checking a remote control system requires determining that the send ing part is working and that the receive part is working..The best scheme is to check them together. Then, if they work, check the range.
35,280
Certainly, a spectrum analyzer would be useful for detecting an RF signal.
You can turn your PC into an RF spectrum analyzer by using SDR USB module (SDR = software defined radio).
28,512
Now I realize that we have all been assuming that it is a remote control failure. Has it been verified that the gate system is OK?? A poppedfuse or tripped breaker would also prevent a gate from opening.
In addition, really, has it been verified that the rest of the gate system is functioning correctly?? I HAVE been requested to repair systems that I found had simply suffered a mains power disconnection.
In the service business it is usually wise to check for the obvious first.
38,919
For 433MHz, Connect a 6.8" (17.3cm) length of wire (for 1/4 wavelength antenna) to one end of a small Schottky signal diode (e.g. 1N5711).
That should give a small DC voltage when the other end of the diode is connected to a voltmeter or oscilloscope if the transmitter is operating and the wire is close to the remote.
28,512
Once again,has it even been verified to be a remote control failure?? Quite a few other parts of a system are more highly stressed and thus more likely to fail.
schmitt trigger
Joined Jul 12, 2010
2,276
@crutschow
Where does one connect the scope’s or meter’s return or negative input? To earth ground like the image?
28,512
Very good question there.
Like I presented elswhere a while ago, and now again. A voltage is between two points. Otherwise it may be just a potential gradient field.
Rather difficult to pin down. Or even "nebulous". (Thanks to Mr. Len Gau for that concept)
LesJones
Joined Jan 8, 2017
4,544
If you have a second remote control does the gate work with that ? If it does then the fault is with the first remote control. If it does not work with the second remote then the receiver is faulty. ( Or both remotes are faulty)
Les.
28,512
Looking back at the photo in post #1, is that device even a diode?? It looks like a transistor to me, since I see three connections.
Does the system function OK with another remote transmitter??? What leads you to suspect that this remote has failed???
