Hey guys, it's my first post here, so I'm sorry if I'm doing it in the wrong place and I really hope you can help me!
I'm developing a dimmer with ESP8266 and I'm having trouble with the TRIAC circuit. I have a zero cross detector developed and it works fine, but when I try to send the signal to the triac, it just works without a load conected (just with the voltmeter).
Explaining better:
When I receive a zero cross signal, I wait a time (via timer interrupt) in a range 0~100 (where 0 is 0ms and 100 is 8.3ms) and set the output to the MOC. If I have just the voltmeter connected to the AC output I can see all the range variation (between 220V and 0V), but if I connect some load it goes to 0V if I try to set the TRIAC after the zero cross signal (if I set the TRIAC while I'm receiving the zero cross signal, I have 220V in the output lol).
Important information:
1. AC Voltage: 220V/60Hz
2. I'm using a transistor to control de MOC because ESP8266 have 12mA of pin current limit.
Here I have a spreadsheet with the timer delay value VS output Voltage with and without load:
Here my circuit (using MOC3041 and BTA41-600V instead):
And the firmware:
Thank you all so much and I'm sorry about the long post. If you need more info, just ask please!
Explaining better:
And the firmware:
ESP FW:
#include <user_interface.h>;//Biblioteca necessaria para acessar os Timers
#include <time.h>
#include <Ticker.h> //Ticker Library
volatile int i=0; // counter
volatile boolean zero_cross=0; // cruzamento por zero status
int sinalOpto = D2;// Output to Opto Triac
int sinalZero = D1;
int dim1 = 0;// dimer level (0 = 100%; 100=0%)
void ICACHE_RAM_ATTR zero_cross_detect();
void ICACHE_RAM_ATTR dim_check();
void setup() {
attachInterrupt(sinalZero, zero_cross_detect, RISING); // define interrupção no pino
timer1_attachInterrupt(dim_check); // timer 12.000 Hz (100x meio ciclo)
timer1_enable(TIM_DIV1, TIM_EDGE, TIM_SINGLE);
timer1_write(6667);
pinMode(sinalOpto, OUTPUT);
Serial.begin(115200);
while (!Serial) {};
Serial.println("Starting...");
Serial.println();
void loop(){
yield(); //delay(1);
void ICACHE_RAM_ATTR zero_cross_detect() { //detecção de zero
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
if (interrupt_time - last_interrupt_time > 2){ //debounce
zero_cross = true; // seta flag de cruzamento por zero
i=0;
digitalWrite(sinalOpto, LOW); // desativa o triac
Serial.print("crossing ");
Serial.println(millis());
last_interrupt_time = interrupt_time;
void ICACHE_RAM_ATTR dim_check() { //timer
if(zero_cross == true) {
if(i>=dim1) {
Serial.print("Setting ");
digitalWrite(sinalOpto, HIGH); // ativa o triac
i=0; // reseta contagem
zero_cross = false;
else {
i++; //
timer1_write(6667);
