For the record, just so you know the general tact I would take in responding to some of those points—because it's frustrating to get NO reply—ontologically we're interested in absolute BASE, indivisible phenomena all definitions are based on.
So that means, for example, a "trit" is just another axiomatic element being defined as a subset of bit. Indeed, you can define a trit componentally in terms of a bit. That means it's an axiom, not an ontological fundament. One trit is equivalent to log2 3 (about 1.58496) bits of information.
Same applies to an XOR gate. I'm not on board with that QED because an XOR gate is ontologically a contraption of 4 inverted OR gates (NAND gates). The OR gate is the ontological fundamental building block, which is in fact employing the "OR" axiom, or ADDITION operator. An XOR is simply a steroidal, mutually exclusive OR gate. The carry bit is an essential element of the TRUE-FALSE superposition and is being ferried to the next circuit to complete the addition (because a computer is an ADDING machine alone, and it ADDS via OR gates and inverters! — QED AF!).
