Building off of definition of machine, infinity, and natural world information processor,
I believe this here is the beginning of an actual proof hashing that shows "thought is not happening in the brain":
IF the brain is limited to bits/numbers as its sole computational instrument and defining mechanism of the person who is supposedly representing it,
THEN
all of its references to such person and "things" are simply bits/numbers, and bits/numbers are POSITIVELY MEANINGLESS OR RANDOM to the medium storing them unless ANOTHER outside system attributes MEANING to them for THEMSELVES. The outside system must be something OTHER than bits/numbers, because again, same problem.
To the brain, any "thing" is a unique sequence of binary 0's and 1's. In these 0's and 1's there is no definition of YOU reasoning ANYTHING about ANYTHING. No one 0 cares about any other 1.
THEREFORE
IF human being = soft, carbon-based Siri Watson
Siri, when she "talks about a cube" is not referencing a cube from within the binary data that is causing the vibrations to emulate "talking."
AND
This leads to the absolute essentiality that: IF you exist, you do so apart from the bits/numbers, and YOU must be something super-numeric, and that MUST be part of the nature of axiom INFINITY and KNOWING itself.
Do you see how the brain is essential to the starting reasoning in order to prove it's not where thought resides, and how numbers and bits must be unified as part of this?
THEN
THEREFORE
AND
