Thanks, would something like this also be suitable for powering the motor and sound board as well? I only ask because it says for LED light strip but not sure if that's irrelevant?
Ok, I don't have an exact size for them yet but due to the size of the base of the model, it can't really exceed more than 36mm, the image below shows a speaker with a radius of 30mm. My plan was to have 4 of them spread at 90 degree intervals around the base. Sorry I'm not sure about the impedance and power ratingLet's discuss the speaker.
What is the diameter of the speaker?
What is the impedance and power rating?
Yes I do, is there a way I can do that?I see that you have another thread on the go on the same project. I think that the two threads should be merged into one.
Thanks Ericgibbs,hi Jacob,
For small speakers that post #2 Amp is far to higher powered.
If your small speakers are say 5 ohm or 8 ohm, you could connect the 4 in two parallel pairs.
Lets know the details of the speakers, then we can advise.
E
Update:
A review video for the DROK.
Thanks, that looks interesting, so I would just have to connect my 12V power supply to the input node on the 7805 and connect the player to the output node?This is a stand-alone miniature MP3 player. It plays files stored in a micro-SD card. It can drive a small speaker. The details of how to wire it for different applications are shown towards the end of the advertisement (see the I/O mode). You would need to use a 3-terminal 7805 linear regulator to drop 12V down to 5V to power it.
https://www.aliexpress.com/item/100...earchweb0_0,searchweb201602_,searchweb201603_
As long as the sound would be detectable in a quiet room, I could probably stretch it up to 40mm?hi J,
I guess you are not to bothered about Stereo for such a small installation.
A 30mm speaker will sound 'tinny', no base sound.
E
Is there a link or you just mean to look for something similar to these?
Ah ok, and do they know if they come as small as 40mm? I'm not sure what to search to find similar results sorryI meant something similar because:
(1) They are powered from USB or 5V supply.
(2) They are small.
(3) The sound is exceptionally good.
You can take them apart and not use the case supplied.
