Ok, sorry for my lack of electrical know, so as I understand the wall warts provide a constant stream of power to the voltage they are specified to, and they have safety features built into them, such as fuses? I'm just wanting to make sure the motor would be protected from any power surges.The power supply I showed you is 6VDC, same as the motor's requirement.
Though it is complicated and you may not have time, slip rings are the way to do the power to the lights.
Ok, I'd like to try the slip ring method you suggest, do you think the areas I highlighted would be suitable locations for the rings? The width of the green opening is only around 8mm, I'm guessing I'd need to find a way of increasing the opening.
How would you propose powering the lights since the top piece rotates the power for the lights will also need to rotate correct?
