Just a reminder that you will need 2 conductors through the slip ring, in case, in your enthusiasm, you overlooked that.
Seems reasonable. You probably don't need the barrier but it won't hurt.I have openings along the edge of the inner ring wall where I will try and connect the wire to.
I've created 7mm openings along the underside of the outside ring where I plan to connect the other wire to.
I modelled a small wall between the centre of the 2 rings to make sure they are unconnected.
Does my thinking behind the current configuration look correct?
Ok that's great thanks.Seems reasonable. You probably don't need the barrier but it won't hurt.
Off the top of my head I’d make an indexing cavity in the base and use double sided foam tape.Ok that's great thanks.
One of my other points of concern I have is how shall I secure the DC motor to the base of the platform, since the securing holes only seem to be on the top of the motor?
Could I ask what you mean by indexing cavity, I can't seem to find any online references to it? Do you mean a small recess where the motor can be lowered to sit below?Off the top of my head I’d make an indexing cavity in the base and use double sided foam tape.
Yes, that's what I mean, alternatively a raised "rim" would work. The key is to have it index. The tape would be more than enough to fix it in place.Could I ask what you mean by indexing cavity, I can't seem to find any online references to it? Do you mean a small recess where the motor can be lowered to sit below?
Ok, well I plan on ordering the components first before I get the model 3D printed, so I can measure the exact dimensions of the motor and try and create a raised rim around the area. I'll use the tape as well to keep it held in place, hopefully the rim will provide it with a more robust fix.Yes, that's what I mean, alternatively a raised "rim" would work. The key is to have it index. The tape would be more than enough to fix it in place.
Because the speakers are going to be very small, the size of the model is not very large so the speaker size is going to be limited. It also ties into the design of the structure.Let's get serious here. Why do you need four speakers instead of one?
Are you holding a block party or is this an anniversary music card for the happy couple?
Do you know the difference between 5W output and 500W output?
Did you do a power analysis? How much current @12V or total power do all the devices take?
How many amperes or ampere-hours can your 12V supply provide?
Yeah, I've already got the slip rings sorted, am getting a couple of custom-size copper gaskets, only $10 each. Ordered them yesterdaySomething to maybe help understand the slip ring would be comparing it to a motor commutator but without the breaks that create the motor poles. So in essence a solid commutator. You might be able to make the rings from a raw copper clad pcb.
