How to find a mistake. Sound amplifier circuit board. Need help with troubleshooting
Pashgen
Joined Nov 16, 2017
23
I bought DIY amplifier board.
And now I am trying to find what I did wrong. It can work for about 2 seconds and then sound dissappear.
But power stays on, and LED is glowing
I connected 24 volt toroid to start the board. In description it says that circuit is designed for 12 to 36 AC voltage. I checked tor, and it's all good, there is 24 volt AC.
I guess I should start looking at power first. Such as diode bridge. I got multimeter to troubleshoot. But I don't want to power up amplifier until I hear opinion of more experienced people.
Please help me to find mistakes. I am learning.
bwilliams60
Joined Nov 18, 2012
1,450
Can you take some really good clean pics of the soldered side of the board and post them up. Also the capacitor in the 4th picture labelled 10U it looks like, is the top of it domed or is that just the camera angle.
lastly, it may help you if you draw out a schematic for your project so that you and others can follow along in your diagnosis. Surprised it didn't come with one. Perhaps the manufacturer has one?
LesJones
Joined Jan 8, 2017
4,544
Tracing the power input circuit it looks like it is designed to work with a transformer with a center tapped secondary. You only seem to have two wires connected between the transformer and the board. The DC common rail will float to some unknown voltage with respect to the main positive and negative rails.
Les.
Pashgen
Joined Nov 16, 2017
23
Les.
Yes! It worked! Thank you so much!
Audioguru again
Joined Oct 21, 2019
6,826
The LM3886 amplifiers are smart, read about it in their datasheet. If they detect over-heating then they shutdown (mute). They do not burn up. The amplifiers are class-AB and the datasheet shows that with 12W into 8 ohms, the heating is 14W.
The photos show a stereo amplifier but the printed circuit board is for a mono amplifier.
With your 24V center-tapped transformer, the output power into 8 ohm speakers at low distortion is only 12W per channel.
Pashgen
Joined Nov 16, 2017
23
Just finished it. Here is pics:
I found old 24v fan. I think it's OK to connected like that. Seems fine.
And I used old cpu heat sink. Applied Thermal paste. Testing it now. Sounds awesome! Everything cold!
Thank you for your help :)
LesJones
Joined Jan 8, 2017
4,544
The heatsink would be better rotated by 90 degrees so the fins are vertical. With just convection cooling the airflow would be between the fins and the same with the way the fan is mounted. An alternative would be to move the fan to the end of the heatsink so the airflow was between the fins.
Les.
