(Solved) How can I fix my PC mouse?
wayneh
Joined Sep 9, 2010
18,170
I've tested the green cable soldered area from one side of the IC and the other side of the IC, and it beeps. I've tested 2 different female USB. So what it seems to be is that the green cable "D+" is broken in the middle or the USB contact is not working?
I think you've got it. At least you have something you must pursue. It obviously won't work if there really is no continuity in that wire. Now the question is, where is the flaw? An artifact of testing is always a possibility you have to keep in mind. Check and recheck.
rambomhtri
Joined Nov 9, 2015
606
I'm doing this tomorrow, but one question: Can a broken green cable (D+ cable is open) produce this error of a loop of recognizing and not recognizing?
When my solder sucker arrives, I'm gonna replace the USB cable and see if it works. For now, there's not much more I can do, right?
rambomhtri
Joined Nov 9, 2015
606
Alright, I've tested the very same female USB on the PCI with the USB cable (of other mouse) I'm trying to replace, and all the cables worked nice, red, black, green and white. The same cables only gave 1ohm, instead of the 4ohm I'm getting in the original broken USB cable of the broken mouse.
Nevertheless, in this older mouse, there are 5 cables, instead of 4. There are 2 different black cables (one is thicker), both connected to the black "pin 4" (ground).
What should I do with the extra black one?
Join them, tin them, and solder them through the same hole?
Why there's an extra black?
Is one of the black cables a shield. Usually heat shrink is placed over the shield. it would be thicker. Clear heat shrink is what I use.
Shields are usually connected to ground on one side only. In the case the computer side. In other cases, like sensors, the signal originating side is better providing there is a ground nearby to connect to.
Note this cable: http://www.l-com.com/usb-usb-revision-20-compliant-bulk-cable-20-awg-power-conductors there is a twisted pair for data, two wires for power and a shield.
Shields are usually not de-braided, but the wires are brought through a puncture wound in the shield.
I've had USB wireless mouse issues with the Microsoft wireless blue. I like the mouse. The receiver/transmitter dies. It's a USB 1.1 mouse.
I wish the mouse had a separate power switch. I didn't find anything obvious. I've used the ebay replacement strategy, but the last time I added the following http://www.l-com.com/usb-usb-surge-protector-type-a-type-a-panel-mount-style-with-pigtail-cable-12 USB surge suppressor which was about 2x more expensive than the mouse.
There is no protection internally on the receiver, so external protection makes a lot of sense especially with a mouse that plugged in and out a lot on a laptop.
My recommendation is to replace with an ebay mouse and get a surge suppressor for USB especially if it's USB 1.1.
The ROHS solders have a high melting point. There are products that lower the melting point. The holes are generally plated thu and it's difficult to remove components. The commercial braids have flux on them. The braids and the solder sucker are first line defense. The sucker with the vacuum pump is much better. Once you remove the solder, it sometimes helps to add some back and then suck it out. That's not intuitive.
When soldering, heat the more massive item.
if you were soldering a simple resistor, the iron would push the lead to the side of the hole and heat the lead and pad separately. The solder would be applied to the lead on the opposite side of the tip. When actually soldering, do not apply solder to the tip. Heat the object and apply solder to the component lead.
You do want to tin the tip and clean it off with a wet towel or sponge. Don't file the tip. They are usually iron clad and filing removes the iron cladding.
rambomhtri
Joined Nov 9, 2015
606
OK, but what do I do now with the extra one?
I only have 4 holes in the mouse I'm trying to repair. Ground, D+, D- and 5V. I don't have a shield hole. Nevertheless, notice both black cables were connected to the ground. Should I join both black cables and solder them to the ground hole?
rambomhtri
Joined Nov 9, 2015
606
Yeah!!!!
It's working again! It's finally working again!
Wow, I didn't expect this :eek:
Now you guys know that when a mouse suddenly stops working, and the PC's recognize it and don't recognize it in a loop, it's because the green cable, or white may be, is broken.
cmartinez
Joined Jan 17, 2007
8,862
Yeah!!!!
Mmmhhh... now you've made me feel BAD for trying to discourage you at the beginning of this thread :(
But I'm really glad you made things work out :)
Now it's not just you who has learned something new :D
rambomhtri
Joined Nov 9, 2015
606
Hahaha, yeah. I'm gonna share here some pictures of the final results. This is really my very, very first work. I've never used an iron soldering before, I've never soldered before, lol.
cmartinez
Joined Jan 17, 2007
8,862
Well... my advice to you now is don't stop here... keep going and start by learning the basic stuff. The sky's the limit, and we're here to help you reach it. Good luck!
