[SOLVED] Brown Black Yellow (or Green) what do you see?
Tonyr1084
Joined Sep 24, 2015
9,744
View attachment 358555Now that I've posted it -it looks green here. But under bright light and high magnification it looks yellow to both me and to my wife. I'm the one with Red/Green deficiency. Upon measuring with an Ohm meter shows 98KΩ. So it must be green, even though I see yellow.
Another color hard to see for me is the difference between Blue and Violet. Given enough of the color and bright enough light when I examine the color - if it looks blue and has red tinges to it - I know it's violet. But otherwise I'm sunk.
And to think I made a living in the electronics industry. Somehow I managed to get it right every time.
SamR
Joined Mar 19, 2019
5,535
My wife is an artist and retired art teacher, and she is no help to me (red/green deficient) when I can't tell the color. The older carbon composite resistors aren't too bad, but I stock the 1% metal foil ones which are terrible for me to "see". I keep the trusty chineseum component tester in arms reach.
WBahn
Joined Mar 31, 2012
33,188
It looks yellow to me, but photos can definitely be deceiving.
If it's green, then the value would be 10x10^5 = 1 MΩ = 1000 kΩ
For it to measure 98 kΩ, which is 2% below 100 kΩ, it would be 10x10^4 which would be BLK-BRN-YLW
Tonyr1084
Joined Sep 24, 2015
9,744
It *must be* brown black yellow, for it to read 98k.
Yes, you're right. Yellow is 4. 104 = 10-0000 =10 100,000
I can be so dense at times. Both my wife and I agree, the third band is yellow. Weird how the picture renders on my screen. Can hardly see the third color band.
Thanks Trigg.
schmitt trigger
Joined Jul 12, 2010
2,229
Color rendering depends on the light source illuminating an object, also known as Color Rendering Index, and the camera’s attempt to white-balance the image.
Unfortunately, the CRI for common, low cost white LEDs are, to put it mildly, Scheiße. Some cameras have a tough time properly white balancing an image.
panic mode
Joined Oct 10, 2011
5,250
i see brown, black, yellow gold which is 100k 5%.
out of curiosity i checked the RGB values with IrfanView. I see that red and green content is about the same (red slightly stronger) which is a yellow.
to be green, both red and blue would need to be low values.
panic mode
Joined Oct 10, 2011
5,250
this may need some tweaking but should work. it is AutoIt script. compiled version is attached so no AutoIt is needed.
Collor_Picker_To_Text (AutoIt3):
#Region ;**** Directives created by AutoIt3Wrapper_GUI ****
#AutoIt3Wrapper_UseX64=y
#EndRegion
#include <GDIPlus.au3>
#include <GuiConstantsEx.au3>
#include <WindowsConstants.au3>
#include <StaticConstants.au3>
#include <ScreenCapture.au3>
_GDIPlus_Startup()
Global $aNames[12] = ["Black","Brown","Red","Orange","Yellow","Green","Blue","Violet","Grey","White","Gold","Silver"]
Global $aTol[12]   = [0,1,2,3,4,0.5,0.25,0.1,0.05,0,5,10]
Global $aDigit[12] = [0,1,2,3,4,5,6,7,8,9,-1,-2]
Local $hBitmap = _ScreenCapture_Capture("")
If Not $hBitmap Then
    MsgBox(16, "Error", "Screenshot failed!")
    Exit
EndIf
Local $hImage = _GDIPlus_BitmapCreateFromHBITMAP($hBitmap)
Local $iW = _GDIPlus_ImageGetWidth($hImage)
Local $iH = _GDIPlus_ImageGetHeight($hImage)
Local $iNewW = Int($iW * 0.25)
Local $iNewH = Int($iH * 0.25)
Local $hResized = _GDIPlus_ImageResize($hImage, $iNewW, $iNewH, $GDIP_INTERPOLATIONMODE_HIGHQUALITYBICUBIC)
Local $hBmpScaled = _GDIPlus_BitmapCreateHBITMAPFromBitmap($hResized)
Local $hGUI = GUICreate("Resistor Picker - VIOLET FIXED v4", $iNewW, $iNewH + 120)
GUISetBkColor(0xFFFFFF)
Local $idPic = GUICtrlCreatePic("", 0, 0, $iNewW, $iNewH)
_SendMessage(GUICtrlGetHandle($idPic), 0x172, 0, $hBmpScaled)
Local $idLabel = GUICtrlCreateLabel("Click band -> VIOLET PERFECT", 10, $iNewH + 10, $iNewW - 20, 90)
GUICtrlSetFont($idLabel, 11, 800, 0, "Consolas")
GUICtrlSetColor($idLabel, 0x000080)
GUISetState(@SW_SHOW)
Global $hOrig = $hImage
Func RGBtoHSV($r, $g, $b)
    Local $max = $r
    If $g > $max Then $max = $g
    If $b > $max Then $max = $b
    Local $min = $r
    If $g < $min Then $min = $g
    If $b < $min Then $min = $b
    Local $v = $max / 255
    Local $s = 0
    If $max > 0 Then $s = ($max - $min) / $max
    Local $h = 0
    If $max <> $min Then
        Local $d = $max - $min
        If $max = $r Then
            $h = ($g - $b) / $d
            If $g < $b Then $h = $h + 6
        EndIf
        If $max = $g Then $h = ($b - $r) / $d + 2
        If $max = $b Then $h = ($r - $g) / $d + 4
        $h = $h * 60
    EndIf
    Local $arr[3]
    $arr[0] = $h
    $arr[1] = $s
    $arr[2] = $v
    Return $arr
EndFunc
Func GetBestColor($r, $g, $b)
    Local $hsv = RGBtoHSV($r, $g, $b)
    Local $h = $hsv[0]
    Local $s = $hsv[1]
    Local $v = $hsv[2]
    If $v < 0.25 Then Return "Black (digit 0)"
    If $v > 0.95 And $s < 0.1 Then Return "White (digit 9)"
    If $v > 0.75 And $s < 0.15 Then Return "Silver (±10%) (×10^-2)"
    If $s < 0.2 And $v > 0.3 And $v <= 0.75 Then Return "Grey (±0.05%) (digit 8)"
    If $h > 40 And $h < 58 And $s > 0.6 And $v > 0.7 Then Return "Gold (±5%) (×10^-1)"
    Local $bestIdx = 1
    Local $bestDiff = 999
    ; Brown ~30°
    Local $diff = Abs($h - 30)
    If $diff < $bestDiff Then
        $bestDiff = $diff
        $bestIdx = 1
    EndIf
    ; Red ~0°/360°
    $diff = $h
    If $h > 180 Then $diff = 360 - $h
        $bestDiff = $diff
        $bestIdx = 2
    EndIf
    ; Orange ~35°
    $diff = Abs($h - 35)
        $bestDiff = $diff
        $bestIdx = 3
    EndIf
    ; Yellow ~55°
    $diff = Abs($h - 55)
        $bestDiff = $diff
        $bestIdx = 4
    EndIf
    ; Green ~120°
    $diff = Abs($h - 120)
        $bestDiff = $diff
        $bestIdx = 5
    EndIf
    ; Blue 210-250°
    If $h >= 210 And $h <= 250 And $s > 0.4 Then
        $bestIdx = 6
        $bestDiff = 0
    EndIf
    ; Violet 250-310°
    If $h >= 250 And $h <= 310 And $s > 0.4 Then
        $bestIdx = 7
        $bestDiff = 0
    EndIf
    Local $sResult = $aNames[$bestIdx]
    If $aTol[$bestIdx] > 0 Then $sResult = $sResult & " (±" & $aTol[$bestIdx] & "%)"
    If $aDigit[$bestIdx] >= 0 Then $sResult = $sResult & " (digit " & $aDigit[$bestIdx] & ")"
    If $aDigit[$bestIdx] < 0 Then $sResult = $sResult & " (×10^" & $aDigit[$bestIdx] & ")"
    Return $sResult
EndFunc
While 1
    Local $msg = GUIGetMsg()
    If $msg = $GUI_EVENT_CLOSE Then ExitLoop
    If $msg = $idPic Then
        Local $info = GUIGetCursorInfo($hGUI)
        If IsArray($info) And $info[4] = $idPic Then
            Local $x = $info[0]
            Local $y = $info[1]
            Local $origX = Int($x / 0.25)
            Local $origY = Int($y / 0.25)
            If $origX < 0 Then $origX = 0
            If $origX >= $iW Then $origX = $iW - 1
            If $origY < 0 Then $origY = 0
            If $origY >= $iH Then $origY = $iH - 1
            Local $pixel = _GDIPlus_BitmapGetPixel($hOrig, $origX, $origY)
            Local $r = BitAND(BitShift($pixel, 16), 0xFF)
            Local $g = BitAND(BitShift($pixel, 8), 0xFF)
            Local $b = BitAND($pixel, 0xFF)
            Local $color = GetBestColor($r, $g, $b)
            GUICtrlSetData($idLabel, _
                "RGB: " & $r & "," & $g & "," & $b & @CRLF & _
                "-> " & $color)
            GUICtrlSetColor($idLabel, 0xD60000)
        EndIf
    EndIf
WEnd
_GDIPlus_ImageDispose($hImage)
_GDIPlus_ImageDispose($hResized)
_WinAPI_DeleteObject($hBitmap)
_WinAPI_DeleteObject($hBmpScaled)
_GDIPlus_Shutdown()
GUIDelete($hGUI)
