Solar-Powered Smart Street Lighting with Motion Detection using LT Spice
bossjeph
Joined Jan 28, 2025
Can someone help me with this?
1. Determine the required solar panel size, solar charge controller (Maximum Power Point Tracking) / BMS (Battery Management System) and battery storage capacity to ensure
continuous operation of 12 V, 37 Watts, street lighting system for a minimum of 12 hours under low sunlight conditions
2. Design and simulate a complete solar power circuit (including solar panel, charge controller, battery, and lighting system) that automatically switches the LED street lights on during dark or low light conditions. The system should incorporate energy-efficient
components, such as LEDs and PIR motion sensors, with a switching mechanism (using diodes or transistors). The goal is to achieve at least a 30% reduction in energy consumption compared to conventional systems without motion detection. No Microcontroller should be used.
Design the solar panel, charge controller, and battery setup.
• Lighting and Motion Detection Circuit:
• Use a PIR sensor to detect motion and control the brightness of the LED lights.
• Simulate the system in LTSPICE to verify functionality.
System Features:
1. Solar Power:
• A solar panel charges a battery during the day.
• At night, the battery powers the LED streetlight.
2. Motion Detection:
• PIR sensors detect movement within a specified range.
• Lights brighten to full intensity upon detecting motion and dim or turn off after a
set period of inactivity.
3. Energy Efficiency:
• Use high-efficiency LED lights to minimize power consumption.
• Implement a battery management system for optimal performance.
ericgibbs
Joined Jan 29, 2010
21,643
hi boss,
Welcome to AAC.
As this is a College assignment, please post your best attempt at answering the question, we can then help you.
Moderation
