It wants to be the next trend. What is your opinion ?
Mine derives from 'if the utility allows it, is beneficial for the utility' not for the user, from what I understand.
The system uses solar panels ----> to a DC to 120VAC inverter feeding mains ----> into a dwelling outlet to power loads.
Missing here :
- Supplies power to neighbors too.
- The utility billing the neighbors for energy they use and your balcony generated.
- The utility does not need to invest in more generation equipment nor maintenance.
- Some bad accidents will happen from falling equipment as gravity is always on.
- Do no work while an outage, your 'balconied' system will be off.
- If has batteries, will not store sheet if charged, but did cost your money
- If has batteries, cannot provide power to the dwelling anyway.
Missing here :
