panic mode
- Joined Oct 10, 2011
- 5,476
and issues could be due to either hardware or software.
The 120 Ohm resistors don't bias anything. They are simply the line termination resistors. Careful reading of the datasheet shows that (like almost any other RS485 recever) the reciever output voltage is guaranteed to be H at a receiver differential input voltage > 0.2 V and guaranteed to be L for < -0.2 V. Between those values the output voltage is not guaranteed. In contrast to other manufacturers, MAXIM (Analog Devices) doesn't specify internal weak pullups or -downs when the driver is disabled. Usually these are in the 50 kOhm range. Applying Ohm's law with 120 Ohm termination leads to a differential voltage of 6 mV, well in the undefined area. Any noise can cause undefined toggling of the Rx output.The 120 ohm termination resistors are the bias resistors for this particular chip. Other chips (such as the SN65HVD1176) may require them, but not the one the TS is using. The TS is using the MAX485ESA+T, check its datasheet.
| Thread starter | Similar threads | Forum | Replies | Date |
| A | RS485 Communication Issue with MAX485 – Unable to Connect 28–32 Sensor Nodes | General Electronics Chat | 58 | |
| V | RS485 hardware connection issues. | Microcontrollers | 22 | |
| N | USB to RS485 DB15 Male Cable | General Electronics Chat | 7 | |
| V | RS485 Architecture | Microcontrollers | 12 | |
| V | Data Mismatch in RS485 communication | Microcontrollers | 3 |
