Problem with Ramp signal Generator using IC 555
Pr1y4n5hu
Joined Apr 21, 2022
According to theory the time period for ramp signal generated using the following circuit should be:
\[ \frac{2}{3} \frac{V_{CC}.C_{1}.R_{1}.(R_{1}+R_{2})}{V_{CC}.R_{2}-V_{BE}.(R_{1}+R_{2})} \]
Now... putting the value of Vcc, R1, R2, VBE, RE... the time period comes out to be around 0.9ms.
But from the simulation it appears to be around 3ms.
Pr1y4n5hu
Joined Apr 21, 2022
Please ignore the values on the hand-drawn circuit attachment. The value i calculated by formula was by taking R1,R2,Vcc,VBE, C1 same as in the spice simulation.
Ian0
Joined Aug 7, 2020
13,278
Does the voltage at the junction of R1 and R2 look wrong to you?
Plot it and see what it does.
Where is Re in your equation?
Pr1y4n5hu
Joined Apr 21, 2022
View attachment 266763View attachment 266764
im sorry its ...
\[ \frac{2}{3} \frac{V_{CC}.C_{1}.R_{E}.(R_{1}+R_{2})}{V_{CC}.R_{2}-V_{BE}.(R_{1}+R_{2})} \]
Pr1y4n5hu
Joined Apr 21, 2022
im sorry its ...
yea it should be ~3.4V its showing 4.3V
but when i plotted it its showing a 3.4V signal
38,805
To minimize the effects of transistor beta variation and transistor Vbe change with temperature, you can use a two-transistor current-mirror to generate the constant current (below), that only requires one resistor to establish the charging current :
The capacitor charging current is nearly (ideally) the same as the current through R5.
