Crossing within differential pair problem
mondo90
Joined May 16, 2025
130
Hi, I found myself in a situation like this:
I don't have a good solution how to get out of it. Simple switching either component to top/bottom layer will cause other pairs to cross. Same if I rotate their relative positions. The only solution that untangles it is this:
However, I wonder if this will have a chance to work? I am concerned about the signal impedance discontinuity. Maybe I should all ground vias next to both passing vias? Both blue and red traces will have a solid gnd plane right below. This signal is 1,5ghz.
mondo90
Joined May 16, 2025
130
@joeyd999, heh, are you say nothing to worry about right? Not an expert on 1.5Ghz then how can you advise here? :)
This is how I routed all 3 pairs:
This is 4 layers board. L1 and L4 red and blue signal respectively. L2 and L3 will be solid ground planes.
There is a 0.05mm length difference in clock N/P pair but negligible. Also, 0.4 diff between clock pair and data pairs.
Any feedback very welcome :)
Thanks!
joeyd999
Joined Jun 6, 2011
6,478
I didn't say that. I said I'd buy you a beer if it adversely effected proper operation.
That beer would be cheap compared to your cost if it did make a difference.
At least I disclaimed my limited expertise. You're asking questions on the internet: believe nothing, verify everything.
Especially when beer and high speeds are involved.
Irving
Joined Jan 30, 2016
5,195
Putting those GND vias will have no effect if you already have a ground plane. At 1.5GHz you need to consider those tracks as a transmission line and ensure impedance matching else you will potentially have EMI/EMC issues. The width and spacing of the traces are important. What chip is that feeding?
mondo90
Joined May 16, 2025
130
The GND vias are there to provide the return path in the nearby via. Sure, I will have ground reference planes below or above the the signal traces but this is lost in via - hence I added ground vias.
As for impedance matching - yes I will do my best to match them using proper spacing and geometry. However my concern here is the middle, clock signal,which is not symmetrical on one end, doesn't travel in par, and this is all because I had to "untangle" it. I wonder if that alone can break that signal.
The chip is esp32p4.
28,488
Without seeing more of the PCB it is difficult to verify that my suggestion will work.
This is a classic case of the TS deciding that there is only one possible way to solve the problem, and that the only place for any fix is right there, which unfortunately does not seem to work.
Show us an inch or two surrounding that problem area, please.
AND, I seem to have missed the part about the circuit working at 1.5 GHz.
drjohsmith
Joined Dec 13, 2021
1,662
you mention changing the components side or orrientation
if the other lines that would be swaped in this case are slower, id look at streightening the clock out .
lichurbagan
Joined Jul 4, 2025
137
At 1.5 GHz, I would be more concerned about maintaining symmetry through the transition than the simple fact that the pair crosses. If both traces experience similar via structures and reference planes remain continuous, the impact is often much smaller than people initially expect.
Adding nearby ground vias can help provide a cleaner return-current path through the transition and may reduce discontinuities. If possible, I'd also check the differential impedance through the crossover region with a field solver or SI simulation.
There are some good differential pair routing discussions that cover symmetry, skew, impedance control, and via transitions in more detail. This guide might help: https://www.pcbway.com/blog/Engineering_Technical/Best_High_Speed_PCB_Design_Practices_06ad7b8a.html
For a 1.5 GHz signal, I'd mainly focus on keeping the two traces electrically similar and ensuring the reference plane remains intact through the crossover region.
drjohsmith
Joined Dec 13, 2021
1,662
Did the op not say they were on a 4 layer board , single ground plane single power plane.
What would the ground via do ?
How would the reference plane stay intact as you mention , with one trace going through a resistor over the other ?
Could you suggest to the op the layout you'd recommend ?.
mondo90
Joined May 16, 2025
130
Thank you for your responses and sorry for the late one from me - did not get email notification.
Yes this is a 4 layer board with:
L1: Most of the signals including 3x differential pairs for MIPI CSI, USB diff pair, and SDIO (4bit) to name the fastest signals in order
L2: GND plane
L3: GND plane
L4: Power: buck converters, LDO, etc
Here is the MIPI CSI 2 area as I have it now:
The biggest concern is the clock pair which I had to untangle. You can't see the ground plane below, as I turned it off for now but it will be there. Note the distance is very short 5mm only.
I also started routing the USB pair:
Someone mentioned the trick with placing a 0Ohm resistor in series, it sounds temping but this discontinuity will likely do more harm than good huh? Any comment to my layout highly appreciated! :)
drjohsmith
Joined Dec 13, 2021
1,662
L2: GND plane
L3: GND plane
Usb
You would normally put the connector and the driver on the same side of the board , saves vias
F General Electronics Chat 3
