testing a zero crossing triac optocoupler
denison
Joined Oct 13, 2018
334
Hi all, I want to be able to test for an open circuit at the mains input of the opto. I have seen somewhere that over 5v the mains is disconnected. So I have used a 2.7v connection and then on connecting the other side you might expect a 2.7v drop over a connected 1000 ohm resistance.
Not getting this on an opto I am testing.
Do you guys think this is a valid test? Or is the another test to test if the opto is working?
Ian0
Joined Aug 7, 2020
13,298
If it fails, it will most likely fail short. Just do a continuity test across the output terminals. If it is open circuit, it is probably OK.
denison
Joined Oct 13, 2018
334
It may be open circuit in operation Ian. If it was shorted I would have been getting a voltage over the load. That is why I have suggested that test and need to know if is a valid test or not.
QUOTE="Ian0, post: 1837376, member: 719943"]
[/QUOTE]
