Testing LEDs on a PCB
Autobike
Joined Feb 23, 2018
110
Hello. i need a small help :)
This is about three LED indicators on a DVR. they are named as POWER, NET and HDD.
At the moment the POWER LED is not working. the NET and HDD LEDs are working fine.
so first i got the voltage readings.
i think the readings are ok.
then i did a diode test for all three LEDs and these are the results i got.
as you can see the working LEDs show OL in both direction. can someone elaborate this. Thank you so much.
WBahn
Joined Mar 31, 2012
33,326
Doing a diode test on an LED in-circuit is largely meaningless. You don't know what the impact of the rest of the circuit that is around it.
The right-hand solder connection on the POWER LED looks a bit suspicious and might be a cold solder joint.
Did the POWER LED ever work?]
Are these all the same color of LED? 1.46 V is probably too low to turn on a visible LED, so either the LED has failed as a resistive short (pretty rare, but not impossible) or something else in the circuit is either clamping the voltage or otherwise preventing it from developing full voltage.
It should be a simple matter to desolder the LED from the board. That will let you test the LED directly to confirm whether it is good or bad, and also let you test the board without the LED load to see if it is generating enough voltage and current to drive the LED.
Autobike
Joined Feb 23, 2018
110
Hello. i have a small update. today while i was getting the readings, the POWER LED began to work as usual. at the same time i took the voltage reading across its terminals and it was 1.711V. it stayed on for a few minutes and then turned off itself. after that i got its reading and it showed 5.22V.
System works fine. other two LEDs work fine. hard drive, network access and all are working as usual. even the USB port works well which is on the same PCB board just under these LEDs.
@crutschow thank you.:)
@Irving thank you. i tested them and got these readings
@WBahn thank you. yea the LED had been working for last couple years. i noticed this fault a few days ago. POWER LED is a red color one. the other two are green/yellow LEDs.
@dl324 thank you. it's quite handy.
WBahn
Joined Mar 31, 2012
33,326
That would be quite consistent with there being a bad solder joint. The one at point B in the diagram looks pretty suspect. You might just touch it up with an iron and maybe a bit of flux and see if that fixes the problem.
Autobike
Joined Feb 23, 2018
110
thank you so much. will do it and let you know. do you have any idea why the POWER LED gets 5.2V ?
WBahn
Joined Mar 31, 2012
33,326
If the problem is a bad solder joint that is disconnecting the LED lead, what you are measuring is the open-circuit voltage which means that there is no drop across the current limiting resistor. Assuming the resistor R2 is the current limiting resistor, and assuming I'm making out the print on it correctly and it says 101, making it a 100 Ω resistor, and assuming that the 5.2 V is the voltage on the other side of that resistor when everything is working fine, and assuming that the voltage across the LED is 1.7 V when it is working, based on your measured results, (note how many assumptions are going into this) then the normal current in the LED would be about 35 mA, which is quite a bit more than I would expect (I would expect about a third to a half of that). But that probably just means that one of my assumptions is wrong.
Irving
Joined Jan 30, 2016
5,195
5v +/- 0.25v is a standard power rail in almost every piece of electronics. If the LED is working correctly the voltage across it should be 1.7 - 2v typically, but if it is open-circuit, either internally or due to a bad solder joint externally then no current flows through it or the resistor (R2 nearby) so the voltage that appears across the LED is the full supply voltage.
WBahn
Joined Mar 31, 2012
33,326
Id R2 is marked 102 (still looks a bit more like a 1 to me, but it is far from clear and my eyes are far from good), that would make the nominal current around 3 mA. Lot's of LEDs today can work fine at that, so that is not unreasonable.
Autobike
Joined Feb 23, 2018
110
@WBahn thx a lot for the clarification. now i got it. will remove the LED and check it separately. if it's bad i'll replace it with a new red color one. will update you with the pics.
@Irving thx a lot for the diagram and explanation. now it's clear. will update you soon.
BobTPH
Joined Jun 5, 2013
11,674
Try reheating the solder as already suggested. That will almost certainly fix it, based on the info you have given.
dl324
Joined Mar 30, 2015
18,500
There's no need to do remove the LED to test. If indeed the joint has gone cold, reflowing the solder will correct the problem. If reflowing the solder doesn't fix the problem, it could be a bonding problem inside the LED. In that case, it would need to be replaced.
I find it interesting that a low current application could have this sort of problem. I've had to reflow solder in the lamp control module on one of my old BMWs, but that was a high current situation (and a known problem).
wayneh
Joined Sep 9, 2010
18,182
I think you have all the information you need but I'll mention one thing I do: I use a 9V battery in series with a 1K Ω resistor and test leads as a handy LED tester. One tap and you'll know whether the LED works.
WBahn
Joined Mar 31, 2012
33,326
It's not that the joint has "gone" cold. It was a cold solder joint to begin with. Over time, oxidation has built up between the solder and the LED lead resulting in an increasingly iffy contact connection.
The hydraulic test stand that we used when I was working F-15s had an intermittent problem in which it wouldn't start up (once it started, it never shut down unexpectedly) that the had shop guys found could be solved by kicking the side of the test stand (the test stand was something like ten or twelve feet wide, seven feet high, and four of five feet deep) near the floor. Over time, however, the problem occurred more often and you had to kick it harder and more times to get it to go. Since we weren't authorized to do repairs on the test stand, I came in at night and tore into the back of the test stand (very carefully, as it used 880 VAC three-phase power), focusing on what was down near the area that we kicked. There was a PCB there and I took it off and inspected it and found a cold solder joint on a relay pin. So I put things back together and went and bought a soldering iron and some solder from Radio Shack the next day and then went in the following night and did the repair. Eventually, one of the civilians remarked on how the test stand problem seemed to have gone away.
dl324
Joined Mar 30, 2015
18,500
i replaced it with a new one and it's working now. it was a 3mm red color LED.
Congrats!
It seems like it's too bright to me. If it's where you can see the LED in a room with ambient lighting reduced for viewing a TV, I'd think about using one that wasn't as bright. Otherwise, you might be tempted to cover it with something like tape.
I have a sort of outlet box/strip that has 6 outlets and 3 USB charging ports that plugs directly into an outlet. The on indicator is a blue LED that's much too bright. I covered it with black electrical tape.
EDIT: add picture
