Filter problem
Homebrew1964
Joined Nov 22, 2024
289
Well not so much of a problem but what i am trying to do is have a little filter fun, i have posted the circuit i am playing with, it is the filter section from a colour organ i found online consisting of 3 channels (filters) bass, middle and treble, i have only built the middle filter and replaced R8 with a 10K pot set to around 5K, the circuit works, as i turn the pot the output varies as the filter changes which is what i wanted but why do i only have the top half of the waveform appearing at the output?
My input signal into R7 is 1kHz at 1.75V AC coupled and is seen in the yellow trace, my output is the purple trace.
I have got so far and now i'm stuck, i was expecting the full sinewave on the output, the collector of Q3
ronsimpson
Joined Oct 7, 2019
4,901
If your goal is to see a sinewave on the collector, then the transistor needs to be turned 1/2 way on with no signal.
Add a resistor that pulls down on the base to turn on the transistor. The bottom end of the resistor can go to ground, or it could just be B-C of the transistor.
Homebrew1964
Joined Nov 22, 2024
289
All that did was increase my current consumption and my output waveform disappeared altogether with a 4K7 resistor.
Homebrew1964
Joined Nov 22, 2024
289
I've just been giving that circuit some thought and i can now see why only the top portion of the signal is needed....the proverbial penny has dropped :D
I should think about the theory behind my circuits before bothering you people....sorry for being dumb :p
