Please somebody tell me what will be output watts of this PWM circuit
Jack Maz
Joined Nov 2, 2021
Detailed description and website link are below.
Parameter:
1>.Product Name: pWM 4-Wire Fan Temperature Controller
2>.Work Voltage: DC 11V~55V
3>.Work Current: 0.1A(MAX)
4>.Fan Current: 5A(MAX)
5>.PWM Range: 5%~100% or 0%
6>.PWM Frequency: 20KHz/2.5KHz
7>.PWM Signal Amplitude: 10.5V(no load)
8>.Temperature Measurement Range: -9.9℃~99.9℃
9>.Work Temperature: -25℃~85℃
10>.Work Humidity: 5%~95%RH
11>.Sensor Length: 1 meter
12>.Size: 70.5*40.5*13.5mm
Temperature Controller Speed Governor Display Module for PC Fan/Alarm DC 12V 24V 48V PWM 4 Wire Fan|Integrated Circuits| - AliExpress
ElectricSpidey
Joined Dec 2, 2017
3,317
That controller is designed to drive a single fan.
I wouldn't try to run standard PC fans with that controller with the PWM voltage being 10.5...most PC fans have a maximum of 5 volts PWM signal.
