Hi, can somebody help to explain feedback transistor please
michael1978
Joined Jun 29, 2014
309
Hello to everbody,
can somebody expain how work and what they form feedback capacitor inductor resistor,
if it was only resistor feedback i understand, but this make me dificult to understand with capacator and inductor....
and also L2...thnx.
michael1978
Joined Jun 29, 2014
309
Ylli
Joined Nov 13, 2015
1,092
What is the transistor type, and what is the application? Is this an RF Power output stage? The RLC base to collector can sometimes be used to 'neutralize' the transistors base - collector capacitance. A link to the origin of this circuit would be helpful.
DickCappels
Joined Aug 21, 2008
10,661
It looks a lot like a notch filter with a limited depth. This circuit is rare and probably designed to solve a particular and unusual requirement.
michael1978
Joined Jun 29, 2014
309
This circuits is for rf design, and i build in multisim, with ac voltage of 1v peak, but i dont see any change in circuit i measure voltage and current is the same when i change the frequency
michael1978
Joined Jun 29, 2014
309
Hi, yes is for rf design, but i dont see so much changes when i change the frequency
Ylli
Joined Nov 13, 2015
1,092
I sim'd it in LTSpice and I didn't see any variations in the passband or phase either. I think with that 1K resistor there isn't enough feedback to make any difference.
(I used a 15 volt source on the collector and used a 47k resistor from +15 to the base to bias the transistor - sim'd with a 2n3904)
38,819
Below is the LTspice simulation of the circuit similar to Ylli's version for 1Ω, 10Ω, 100Ω, and 1kΩ values of R1.
L1C1 has no discernable effect on the gain for R1=1kΩ (green trace), the original value, but shows increasing rolloff as R1 is reduced to 1Ω (yellow trace).
michael1978
Joined Jun 29, 2014
309
thnx man, but i dont understand, what they do LC Tank, you can use only one resistor for feedback, why also LC, is possible a lttle bit to explain me more in detail, i know they resononate at 11.25Mhz, but more i dont know, and also my circuits he dont have a Resistor 47k, do you want to send you my software,you understand more than me?
michael1978
Joined Jun 29, 2014
309
Hello, but me i dont understand what they do lc, you can use only one resistor feedback, what for changes they do lc
ericgibbs
Joined Jan 29, 2010
21,573
hi michael,
Look at this link, note the response plot of that series L C circuit.
You see at resonance the series impedance is the lowest value, this means the negative feedback is at a maximum, so the circuit gain is at a minimum.
https://www.electronics-tutorials.ws/accircuits/series-resonance.html
Look at the Yellow line plot in post #11, shows the gain
Update: you recall that you calculated Fres ~ 11.25MHz, compare that with the Yellow plot.
E
EDIT:
Clip from that link.
michael1978
Joined Jun 29, 2014
309
hi michael,
E
EDIT:
Thnx Man, i am reading this article….
michael1978
Joined Jun 29, 2014
309
hi michael,
E
EDIT:
Hi, i read fast the article, at resonance frequency current is at maximum
hi michael,
E
EDIT:
Like i read fast at resonance frequency, the current is at maximum, of xl xc act like a short, only the resistance stay to calucalte, so it dependes how small of large the value of R is, and the current depends on R, I=V/R os is R small more current is R high low current RIGHT?
ericgibbs
Joined Jan 29, 2010
21,573
hi m,
In that circuit a 1k resistor is so large compared to the L and C impedances near resonance, it is 'dominant' so it masks out the effect of the LC.
As the R value is reduced, the LC impedances are effective to a greater degree.
Do you follow OK.?
E
michael1978
Joined Jun 29, 2014
309
hi m,
Do you follow OK.?
E
I think i understand, like you say, "Look at the Yellow line plot in post #11, shows the gain", i see the result, of graph 1Ω, 10Ω, 100Ω, and 1kΩ values of R1.
yes i think i understand now, because i have special sofware, it tells everything about gain and impedance and losse, you just have o put one value for the rest he do, and i dont understand how it works, but now i understand so now is easy to do experments
Thnkx a lot ;)
michael1978
Joined Jun 29, 2014
309
Thnkx a lot ;)
Ohh Man sorry i forget i did not get answer about L2 and R2, what does do L2 or what makes L2 and R2
