Nope just my opinion, but the only way the circuit would behave as the OP stated is the ground has been removed from the shunt.Do you have any justification for that statement?
SG
Front page of the ON Semi datasheet, feature #4.Geez a 1 amp op amp to drive a LED? I don't think the LA6500 will operate as a DC amp in the single-ended mode.
SG
Yeah, I read the spec sheet before but doesn't necessarily mean in every application. All the example circuits I could find using a single power supply were audio output amplifiers. Can't verify as I don't have a LA6500 to test, but if the OP says it works then I stand corrected.Front page of the ON Semi datasheet, feature #4.
http://www.onsemi.com/pub/Collateral/LA6500-D.PDF
I totally agree with AK. But since I am willing to share knowledge it is a chance to explain what else is needed to provide an answer. And sometimes the questions are quite interesting.You are not the first, or even the hundredth person to note that.
Disagree. The part does not become less stable with low output currents; that is no different than driving a speaker with a soft music passage. The big package means you probably will not need a heatsink even at relatively high LED currents. It is overkill and expensive, but there are many aspects of this project we do not know, and some of them might be driving the component choice.I had not realized that the op-amp in this thread was an audio power amp. Those are not a good choice for this sort of application, because they offer too much power gain and are intended to feed a much lower impedance load.
I agree. The inputs of an LM386 can detect a grounded low side current shunt and has an output current up to 566mA.An LM386 makes an excellent comparator and 2-LED driver.
I don't find that on the data sheet I'm using, can you post this page please?Technically speaking, there is nothing wrong with the circuit- the circuit isn't the problem. It's a standard singled-ended non-inverting configuration with a gain of ~9.29
The OpAmp is the problem. This OpAmp will not go closer to the negative rail than 3 volts. See the first page of the datasheet.
It's directly on the 1st page. Max inputs .v. differential inputs. The problem is, you're not understanding how to read the datasheet. Max is 36Vp-p. Differential is 30Vp-p. The power & ground pins determine 'rail' or max range of voltage possible. And whatever that range is, you can't get closer to either rail than 3V in either direction. (36V - 30V) / 2 = 3VI don't find that on the data sheet I'm using, can you post this page please?
Edit: we are talking about the LA6500 correct?
SG
You too. The common-mode input voltage range includes the negative supply voltage when the total supply voltage is not as high as the max allowed supply voltages.The problem is, you're not understanding how to read the datasheet.
