How can an operational amplifier be used to achieve an output of 1.60–2.90 V with an input of 0–1.3 V?
Kevil
Joined Jun 28, 2020
224
How to adjust the circuit so that for an input voltage of 0–1.3 V, the output is 1.60–2.90 V?
38,423
With one less resistor:
Edit: Select R1 and R2 to give 1.6V offset, and then select R4 to be equal to the parallel equivalent resistance of R1 and R2.
This give a signal attenuation of 1/2 at the op amp (+) input, when is then amplified by the non-inverting gain of two from R5 and R6.
Kevil
Joined Jun 28, 2020
224
Perfect, I appreciate your help very much. Be the way how you added comment Os,1.6126903V with arrow to the chart ?
sparky 1
Joined Nov 3, 2018
1,218
Piece Wise snippet is convenient, here is a increment and decrement but having a collection of snippets will give you more information.
V1 in 0 PWL REPEAT(2) (0 0 1 1.3 2 0)
R1 in out 1k
C1 out 0 1u
.tran 0 6
.end
Video shows you how to use any Wav or PWL snippet in order to get a lot done.
38,423
Reasonably simple.
After doing a plot, left-click on the plot title to create a cursor on that plot, and then move the cursor to the point you want to annotate (arbitrarily shown below for 409.6ms).
Now go to Plot Settings and select Label Curs. Pos.
Rinse and repeat for different cursor positions or plot waveforms.
27,362
The specification asks to use a unity gain (Av=1.000) non-inverting amplifier, and an input offset voltage of1.600 volts to the non-inverting input, also with unity gain. The op-amp supply voltages must be positive 5.0 volts AND negative 5.0 volts
panic mode
Joined Oct 10, 2011
4,947
why 5.0V and not 12 or 15V? why is negative supply a must?
as already shown, one can use classic summing amp and single supply. if one is not deriving 1.6V from supply, resistor values become simple too.
27,362
OK, P.M. asks a valid question: I specified +-5 volts because some folks want to go lower, and using 3.3 volts could get into a less perfect portion of the capability of some op-amps. Similar reasoning for the negative supply, being that quite a few op-amps are not adequate towards the lower power supply voltage. Certainly it might be possible that it could be "good enough."
BUT I chose to offer advice that should be sure to work, instead of maybe being good enough, almost.
panic mode
Joined Oct 10, 2011
4,947
it would suffice to say that negative supply is preferred or recommended. a 'must' suggests that nothing else is possible, regardless if acceptable or not.
MrAl
Joined Jun 17, 2014
13,686
That's interesting that you noticed that some of the resistors could be combined and the result is one less resistor, maybe using Thevenin and Norton.
Also interesting is that if we take that one step further, we can eliminate yet one more resistor bringing the total count of resistors down to just 4.
I'll wait to see if you want to try this reduction or not.
MrAl
Joined Jun 17, 2014
13,686
Nope, I'll leave it up to you.
Ha ha, well ok, some members here like a challenge sometimes. No problem though.
R2 (11.5k) gets eliminated, but some of the remaining resistor values have to change.
I usually look for this kind of thing in linear networks because the number of impedances often decreases when they are connected together in some way.
If nobody else wants to try it I'll post one of the solutions.
27,362
Perhaps close enough is acceptable thru the whole voltage range, but maybe it isn't. There is no reason to not suggest going beyond the barely good enough minimum, since this is not known to be a consumer grade junk project. We did not get repeated orders for machines by delivering barely OK products. That was very much brought home to us with one machine project where we initially lost the order because another company bid a lower price using my description of the performance and accuracy. BUt the competitors machine was not accepted at the buy-off because the accuracy was well outside of the specification. So we got the job a bit late. And our machine was well within the required accuracy, and saved the buyer a great deal because of not needing re-calibration after the quarterly checks.
The point of this tale is that "just barely" is seldom actually good enough. That is one reason that I go for more that just enough.
panic mode
Joined Oct 10, 2011
4,947
i hear you but anyone needing help with this type of question is learning basics. that means not ready to design for production. and unless specs/tolerances are stated, 99% solution is ok - or at least worth mentioning since on chosen OpAmp "Input Voltage Range Extends to Ground" and output is not near rails.
