Agreed, but that only works if you put all the LED in parallel and assume a fairly constant Vf for each, so you have a dropper resistor for each LED - though the TS' approach has been for LED in series so far. Even so, the resistor for 5v @ 350mA is (5-3.2)/0.35 = 5.1ohm @ 0.63W (2W resistor) which is a lot of heat to shift on the 5-LED version. Maybe need to go back to THT parts off board, though messy?I think you worry too much about the current control. A 5V supply and resistor should be fine. Each mug is going to filter a different amount of light through it anyway, so I think they will need to be individually calibrated via the PWM to make the effect consistent. The WS2811 makes that easy to do.
