Need help to make two doorbells work simultaneously
sghioto
Joined Dec 31, 2017
8,750
OK it appears the Red wire is negative. Remove Q2 from the breadboard and connect the video doorbell back up and see what happens.
Anomajaya
Joined Jul 11, 2023
59
Yes, red wire is the negative.
Once the Q2 is removed, I was able to connect the both wires from the video doorbell with the breadboard without activating the doorbell. But none of the buttons activated the other system.
Anomajaya
Joined Jul 11, 2023
59
It was working yesterday meaning the relay module did activate, correct?
Yes. But as I hadn’t connected the 230v side correctly, I was testing it by powering the 230v opto-isolater continuously with AC current. if it was not powered with AC current, video doorbell was activated without pressing its button.
Later I realised, in the real scenario opto-isolator would only be activated by pressing the wall switch.
sghioto
Joined Dec 31, 2017
8,750
That doesn't seem right it should have been just the opposite. May have a bad transistor.
Remove Q2 and leave Q1 installed. Measure the voltage on the output of the video button, should have appx 3 volts.
The voltage at the red arrow junction should be appx 0 volts.
Anomajaya
Joined Jul 11, 2023
59
The voltage between the video doorbell button wires is still 3.06v and the voltage at the red arrow in reference to the negative wire of the 5v supply is almost 0.0v. The voltage at the same point in relation to the negative wire of the video doorbell is also 0v. (Images are attached).
Anomajaya
Joined Jul 11, 2023
59
Then the diode is bad or installed backwards if the relay module does not avtivate.
Once I changed the direction of the diode, relay got activated and then deactivated in a around 2 seconds. But then I saw there is a 5v at the red arrow. And at that time, pressing the video doorbell button did not activate the relay. All these was done removing Q1 and Q2.
When only the Q1 is in place with reversed diode, relay keeps activated all the time.
