Need help to understand operating principle of five level Flying Capacitor Clamped Inverter
Tasnim Hasan
Joined Jun 30, 2026
I built a five level Flying Capacitor Clamped (FCC) inverter in matlab simulink using Fundamental Frequency Shifting (FFS) switching technique. I chose 50Hz as fundamental frequency i.e. 20 ms is fundamental period which is divided into 10 segment (required level * 2). Here, the model schematic and the switching table for the switches is provided. By putting these values I got the desired 5 level stepped output which also provided here. But i couldn’t understand how the model operates actually like how the current flows, how flying capacitor and dc-link capacitor connected, how flying capacitor operates,and ultimately how we got the stepped output waveform. Particularly my problem is regarding how the voltage level E/4 is formed when S1 and S2 switches are on..
I am seeking kind help from the experts regarding this
cwella
Joined Jul 9, 2026
25
Your simulation results look good. For the E/4 output level, it helps to trace the current path with only S1 and S2 turned on and identify which flying capacitors are connected in the circuit at that switching state. Once you map the conduction path and capacitor voltages, the stepped output becomes much easier to understand. If you can share the full circuit or switching sequence, members can walk through the current flow for each voltage level.
