Need help to make two doorbells work simultaneously
sghioto
Joined Dec 31, 2017
8,756
If that works without causing problems with the smart doorbell then remove the resistor and try connecting the negative of the button directly to the negative of the 3 volt supply.
sghioto
Joined Dec 31, 2017
8,756
I have a circuit that can eliminate the 3 volt supply and 3 volt relay module if the previous suggestion works. It uses the 5 volt supply and relay module with two additional transistors.
sghioto
Joined Dec 31, 2017
8,756
I will but have you confirmed there is no issue connecting the negative of the smart button to the power supply ground?
I don't anticipate one but one never knows until tested.
Anomajaya
Joined Jul 11, 2023
59
Ok. I’m waiting for the 2n7000 to be delivered. Probably it’ll be delivered today or tomorrow. I’ll let you know how it works.
Anomajaya
Joined Jul 11, 2023
59
Don't need the 2N7000 to test my proposal. Just connect the 330 ohm resistor from the negative side of the video doorbell button to the negative of the 3 volt supply and see if the video doorbell still works OK.
Understood. I'll test it and let you today evening.
Anomajaya
Joined Jul 11, 2023
59
Yes through 330 ohm resistor, once I connect the negative side of the doorbell with the negative wire of the 3v DC supply, doorbell works fine.
sghioto
Joined Dec 31, 2017
8,756
Set the meter to read DC current at 200ma or so and connect the meter leads directly across the video doorbell button wires so it activates. I need to know how much current it draws.
Anomajaya
Joined Jul 11, 2023
59
For 200mA it gave me nothing. But when I set to 2000microA setting it gave me 30.
sghioto
Joined Dec 31, 2017
8,756
Excellent, one more test. Try connecting the negative side of the doorbell wire directly to the negative of the 3 volt supply without the resistor and test doorbell button again.
Anomajaya
Joined Jul 11, 2023
59
Button Works perfectly even after connecting negative wire of the doorbell switch directly connected with the negative side of the 3v power supply. (That power supply is switched on )
sghioto
Joined Dec 31, 2017
8,756
Try this circuit with the 2N7000.
When the button is pressed for the 230 volt bell the opto-isolator turns on Q2 which shorts the switch wires on the video doorbell which in turns activates the 5 volt relay module to power the 230 volt doorbell.
Anomajaya
Joined Jul 11, 2023
59
Thank you. I’ll test it and let you know tomorrow. I’ll have another 2n7000 tomorrow.
Cheers!
