LTSpice - How to add new Diode
ericgibbs
Joined Jan 29, 2010
21,567
I got the value of 41.72 ohms. But i think it can't be done like this!
hi,
IRL = 5.6/330 = 17mA, so Iz = 1.7mA , so Irs = 18.7mA
Vmin ripple = 6.5v, so Rs has to drop 6.5v- 5.6v = 0.9v at 18.7mA.
So Rs = 48.1R, nearest pref value is 47R...
So using the above method you should be able to calc the value of Rs for your measured Vripple min.
Show me your calculations how you got 41.72R.?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
I used those formulas above to calculate it:
Vz = 5.6V
Rl = 330 ohms
I_rl = 5.6/330= 16.9mA
I_z=16.9mA + 1.69mA=18.6mA
I_Rs=18.6mA + 16.9mA = 35.6mA
And lastelly, using the 1st formula:
35.6mA = (5.65-5.6)/R_s <=> R_s=41.72ohms...
ericgibbs
Joined Jan 29, 2010
21,567
Vz = 5.6V
Rl = 330 ohms
hi,
You dont add these values together again.!
Itotal thru Rs = Irl + Iz = 17mA + 1.7mA = 18.7mA
Try again, almost there.:)
E
ericgibbs
Joined Jan 29, 2010
21,567
Why not? By the Kirchoff laws i can say that I_rs = Iz + I_rl
Izener is only 10% of Irl , your question gives you that information
Irl = 17mA so Iz must be 1.7mA , giving a total of 18.7mA thru the Rs resistor.
So why would you want to add that value to the value of Irl again.??
Your post says: I_rs = Iz + I_rl , which is what I am posting.:)
Irs= 1.7mA + 17mA.
EDIT:
Look at this sim.
Remember Irl is the current thru the 330R
ericgibbs
Joined Jan 29, 2010
21,567
Hum... But why are you simulating that without a bridge... I didn't got your point now... Sorry!
I used a simplified circuit that only shows the components that we are discussing, its set to 6.5V as thats the ripple minimum voltage from the previous bridge.
Do you now understand the way I calculated the Rs etc.??
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ok, i got it...
But the simulation confuses me a lot...
I have calculated an R_s for exact values this way:
I_rl = 16.9mA
I_z = 1.69mA (this is where I think I might be doing something wrong because i don't know if this info is correct, i mean if i got this correctly from the teacher)
I_rs = 16.9 + 1.69 = 18.59mA
R_s = 79.43 ohms
ericgibbs
Joined Jan 29, 2010
21,567
hi,
That 79.43R resistor is much too high a value, its bringing the zener out of conduction, so the 5.6V Vout is no longer regulated.
Look at your asc file run by me to show the Iz and Vout.
Note The Iz and Vout.
Who choose that value for Rs.???
EDIT:
Formula for Rs = [VcMin- Vz]/[Iz+Irl]
Where VcMin = lowest value of voltage due to the ripple on Vc
Its basically Ohms Law
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Jesus, i can't get any of that!
I have added the directive to standard.dio and i get nothing like thaT!
What i get is this:
ericgibbs
Joined Jan 29, 2010
21,567
Thats exactly the same as mine.!
Plot the Vout on its own plot and the Iz on its own plot and post what you see..
EDIT:
I have changed my plot to match yours, they are the same
ericgibbs
Joined Jan 29, 2010
21,567
You have removed the 10mSec delay from the .tran 0 50m 10m, so your plot will be less accurate.!!
ie: lower resolution.
You do not need to plot the first half cycle.
ericgibbs
Joined Jan 29, 2010
21,567
I have told you the formula many times in previous posts
