LED help
Thedax
Joined Oct 22, 2025
148
Red illuminates (as it is not connected to the neg) when powered on think I have this correct now sorry for the confusion.
Thedax
Joined Oct 22, 2025
148
So its connected as image + and - to psu G B to Neg R is not connected to anything, and red is on when powered up.
sghioto
Joined Dec 31, 2017
8,737
OK that's good but to measure the current the meter must be connected between the +12V terminal of the power supply and the +12V power input of the module.
Remove the +12V wire on the module from the power supply and connect it to the Common black lead on the meter.
Connect the red meter lead to the 10A receptacle and set the Dial to the 10A position.
Is this clear?
Thedax
Joined Oct 22, 2025
148
so I think I understand now I need to use the meter to make the connection between the 12v so the voltage will run through the meter, is that it?
thank you for being so patient with me.
