OK that's good but to measure the current the meter must be connected between the +12V terminal of the power supply and the +12V power input of the module.
Remove the +12V wire on the module from the power supply and connect it to the Common black lead on the meter.
Connect the red meter lead to the 10A receptacle and set the Dial to the 10A position.
Is this clear?
so I think I understand now I need to use the meter to make the connection between the 12v so the voltage will run through the meter, is that it?
thank you for being so patient with me.
