Strange. Try the Blue.
T Thread Starter Thedax Joined Oct 22, 2025 148 Oct 30, 2025 #243 Could I have damaged it if I connected it straight to the green and or blue?
S sghioto Joined Dec 31, 2017 8,751 Oct 30, 2025 #244 That doesn't make sense. Disconnect all 3 RGB wires from negative. Do all the LEDs come ON and if so what is the reading on the meter.
S sghioto Joined Dec 31, 2017 8,751 Oct 30, 2025 #245 Thedax said: Could I have damaged it if I connected it straight to the green and or blue? Click to expand... Connected what straight to the green or blue?
T Thread Starter Thedax Joined Oct 22, 2025 148 Oct 30, 2025 #246 All leds light when reconnected to power, I wasn't sure if i connected the black wire straight to the blue and green when I was testing.
T Thread Starter Thedax Joined Oct 22, 2025 148 Oct 30, 2025 #247 So do I test this again with all the leds on?
S sghioto Joined Dec 31, 2017 8,751 Oct 30, 2025 #249 That's the current reading with all 9 LEDs ON ?
S sghioto Joined Dec 31, 2017 8,751 Oct 30, 2025 #251 That's good. But need to redo the test. Connect the G and B RGB wires to negative, leave R not connected or what's also called "floating". Only the RED LEDs should be ON, read meter.
S sghioto Joined Dec 31, 2017 8,751 Oct 30, 2025 #253 Good! Now connect the R and B RGB wires to negative, leave G not connected. Only the GREEN LEDs should be ON, read meter. Finally connect the R and G RGB wires to negative, leave B not connected. Only the Blue LEDs should be ON, read meter.
S sghioto Joined Dec 31, 2017 8,751 Oct 31, 2025 #256 Thedax said: Greens just flash once Click to expand... Doesn't make sense unless you damaged the chip. Are you sure the G wire is not connected to anything and R and B are connected to negative?
T Thread Starter Thedax Joined Oct 22, 2025 148 Oct 31, 2025 #257 Im just putting another fixture on 2 mins
S sghioto Joined Dec 31, 2017 8,751 Oct 31, 2025 #259 Thedax said: Green 0.19 Click to expand... That's with all 3 green LEDs ON
T Thread Starter Thedax Joined Oct 22, 2025 148 Oct 31, 2025 #260 Yes, blue is strange as its 0.04 not as bright
