Transformers, Watts,Volts and amps?
The Darlington transistors in the MindBlower speaker are emitter-followers that have no voltage gain. They use a low input current and produce a fairly high output current. The transformers increase the signal voltage.
When the output voltage across a resistor or a speaker is increased then its current requirement also increases according to Ohm's Law.
