Like I said I didn't look at the component. And Ebeowulf addressed the SIP and DIP question.Maybe I still don't understand shortbus (?)
English please AG. It would be like you asking me the difference in diametral pitch gear cutters and what number to use to cut what number of teeth on a gear.AG said:If you put +5V on the clipper pin #4 then if there ever is an error then the transistor on pin #4 will try to drive the +5V to ground which will cause the transistor to die. The datasheet does not say its maximum allowed current which must be very low since they show it with 10k and 15k
series resistors to drive the high input resistance of a uC.
I read it shortbusshortbus said:Like I said I didn't look at the component. And Ebeowulf addressed the SIP and DIP question.
Inputs on what? what pin? Remember I am a newbieAG said:Why do you have TWO inputs? What signal source are you using that has a differential output?
Hehe, that's awesome!Figured out my pattern pin problem. I changed the color of my background to black and didn't change the pin color layer.
Those are the inputs from the radio is what I thought AG. Tell if I'm wrong(?) So nothing goes to pin #4 (?)AG said:Here is the schematic you posted with my questions on it:
Since its gain is 20 times and with your 16V boosted supply then its input is about 1.5V peak-to-peak when its output begins clipping and sounding awful. The car radio maximum output is about 23V peak-to-peak. Since nobody plays an amplifier that has horrible clipping then they do not say a maximum allowed input voltage. You should attenuate the car radio outputs down to headphones level.Still trying to find out more on the TDA7396. How much input volts it can take on the inputs from the radio. The datasheet says the outputs are rail to rail and no need to bootstrap capacitors if that means the same thing (?). Says it can drive loads as high as 2ohm.
So in other words design, build and create an amplifier that doesn't amplify anything but headphones?AG said:You should attenuate the car radio outputs down to headphones level.
So they can make a radio with all the other stuff in it plus an amplifier built in but if I try to just make an amplifier by itself it will never work ?AG said:The car radio maximum output is about 23V peak-to-peak.
