Thanks MisterBill. I did post earlier about finding a place that would custom wind them for me but I haven't contacted them (yet).MisterBill said:The transformers are not that hard to copy, I have wound transistor output transformers "close enough" to work well and sound OK. And if he wants to make a bunch of them there are companies that can produce as many as he can pay for within 15 miles of my house. Osborne is one of them.
http://www.merrenaudio.com/
I was hoping to find someone closer to where I live but I don't think that is going to be the case. Yes there are alot of them.
This I have kinda looked into to. I also have all the components picked out with close enough specs or better but (two) and those are the transformers. If I had those I could put everything on a breadboard and begin testing. I think I'll spend some of today getting quotes from some of these places.MisterBill said:Circuit boards of that era were not so fine-line and complex. Making a copy to send to a China board house and for a hundred single sided boards probably $5 each or less, if no solder mask and no plated through holes, maybe $3 each.
Now that's encouraging.MisterBill said:It is easy to get 25 watts of audio from a 12 volt push-pull transformer output amplifier if you use good transistors and drive them with a decent (copied) driver transformer.
I wouldn't be so quick to say that. In my searching and reading there are still people out there that ask for schematics or components for these.MisterBill said:A production run of 100 units would run just a few thousand dollars. Then comes what I see would be the really big problem: Nobody would want them.
