Source: https://en.wikipedia.org/wiki/PinoutIn electronics, a pinout (sometimes written "pin-out") is a cross-reference between the contacts, or pins, of an electrical connector or electronic component, and their functions. "Pinout" now supersedes the term "basing diagram" that was the standard terminology used by the manufacturers of vacuum tubes and the RMA (emphasis added).
Yes, the literary work called "Genesis" is in the bible. But, the origin of the universe is not in the Bible.In is correct. Would you say “Genesis is on the Bible”?
Bob
HiTechnical grammar question, which option is correct / more correct / preferred / whatever:
1. The pinout is in the datasheet.
2. The pinout is on the datasheet.
Thanks.
