- Joined Jan 23, 2018
- 28,345
YES, it seems that there had been a reversal.I've tested it out , I got no reading on the first test with the meter on 2k and 20k rage it shows 0. The second test, which is negative terminal of the batt connector and pin 14. I got 0.21 with 2k range. Does it means my battery connector is reversed?
And please return here because there is a lot of wisdom available from some of the participants. And you will see that there are also a lot of folks just getting started. In addition, the disproving of concepts for greater than 100% efficiency is always interesting.
